When I try to boot my motherboard beeps at me. What does this mean?
There are a number of beep code you may experience:
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM isn't inserted correctly.
Short(Beep) continuous POWER supply has a problem
A two-tone siren, generally caused by overheating or out of specification voltages.
Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
The AWARD BIOS offers no other codes - any other error messages are displayed on the screen. Also see Award error codes.
Display card of monitor connected error dus.
The trade of the tools
[ me | specs ] Klipsch Promedia Ultra 5.1 + Sennheiser HD-590
