java cisco 800
  • 49 views sinds 30-01-2008
Is het mogelijk dat een cisco 800 java applets blokkeert.
zodat er bijvoorbeeld op www.gvu.nl bij de vijf knoppen links alleen maar grijze vlakjes komen?
en zo ja hoe krijg ik dit er uit.
show ver:
ROM: TinyROM version 1.2(2)
buenva uptime is 1 hour, 51 minutes
System returned to ROM by power-on
System image file is "flash:aaa0842.bin"
Cisco C801 (MPC860) processor (revision 1) with 43376K bytes of virtual memory.
Processor board ID xxxxxxxxxx
CPU part number 33
Bridging software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
4M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
show ru
xxxxxxx#sh ru
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxxxx
enable password 7 xxxxxxxxxx
ip subnet-zero
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name Ethernet_0 tcp
ip inspect name Ethernet_0 udp
ip inspect name Ethernet_0 cuseeme
ip inspect name Ethernet_0 ftp
ip inspect name Ethernet_0 h323
ip inspect name Ethernet_0 rcmd
ip inspect name Ethernet_0 realaudio
ip inspect name Ethernet_0 smtp
ip inspect name Ethernet_0 streamworks
ip inspect name Ethernet_0 vdolive
ip inspect name Ethernet_0 sqlnet
ip inspect name Ethernet_0 tftp
no ip domain-lookup
isdn switch-type basic-net3
process-max-time 200
interface Ethernet0
description connected to xxxxxxxx
ip address x.x.x.x 255.255.255.0
ip access-group 100 in
no ip directed-broadcast
ip nat inside
ip inspect Ethernet_0 in
interface BRI0
description connected to Internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
interface Dialer1
ip address negotiated
ip access-group 101 in
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer string xxxxxxxxxxxxx
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxx
ppp chap password 7 xxxxxxxx
ppp pap sent-username xxxxx password 7 xxxxxxx
router rip
version 2
passive-interface Dialer1
network x.x.x.x
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit x.x.x.x 0.0.0.255
access-list 100 permit ip any any
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
snmp-server engineID local xxxxxx
snmp-server xxxxx
line con 0
exec-timeout 0 0
password 7 xxxxxx
login
transport input none
stopbits 1
line vty 0 4
password 7 xxxxxxxx
login
  • Koffie
  • Laatst online: 10:35
Koffie
Koffiebierbrouwer
Braaimeneer
Voor zover ik weet staat PNS nog steeds niet voor "Dit is mijn config, los op aub".
Braaikamer - Smoke&BBQ - Huis
