Ik ben niet zo'n audio-specialist, ik d8 dat ac'97 niet zo veel voorstelde wat is dit dan???
EPoX EP-4G4A- calls it " is perfect (host) the audio frequency the board " for
Renewal date: On May 15th, 2002 dynamic renews: Romantic candle
EP-4G4A is the EPoX ÅÍ England science and technology in one section Intel which domestic for a while promotes the 845g chip group's product. Product assigns the reference datum board as Intel the i845g to grind sends the i845g motherboard which the merchant EPoX promotes, the nature is easy to receive more attention. EPoX EP-4G4A has the many advanced technologies, includes supports 533mHz FSB, USB 2.0 and integrates high performance 3d reveals the card, is extremely outstanding. But we pay attention, after EPoX continues EP-8K3A pushes the AC'97 6 sound tracks outputs, still continued to plan strengthened the motherboard the sound effect performance. This section EP-4G4A may say is EPoX the another ¿ž¶Ŝ work which takes great pains in the motherboard sound effect aspect. We think, EP-4G4A already did not have extremely perfect and the outstanding AC'97 specification, called it " is perfect (host) audio frequency board " for.
Audio frequency perfect board EP-4G4A
AC'97 full title Audio Codec'97 (is called AC'97, Italy is " sound effect multimedia digital signal arranges / decoding") is the audio frequency µç·ϵͳ standard which Intel, company and so on Creative Labs together formulates, now the majority of sounds card all follows the AC'97 standard, includes the mainstream CREATIVE SB Live! With SB Audigy. Needs the platitudes is, takes one standard, AC'97 has milestone to sound card development significance. The so-called AC'97 soft sound card, is simulates the hard sound card with CPU the host processing chip function carries on each kind Êý×ÖŽŜÀí, after hands over by outside the digital signal processing sets DAC or the board carries the Codec output.
The EPoX ÅÍ England science and technology extremely likes using ALC AC'97 Codec, ALC650 AC'97 Codec which EP-4G4A uses has has the extremely formidable programmable ability, can real-time to DSP function and so on effect enhancement and 3d effect enhancement. EP-4G4A provided newest ALC650 the Codec chip, worked DAC regarding the Codec official duty (digital simulation transforms) /ADC (Ä£ÄâÊý×Ö transformation) the aspect, ALC650 also does is not ambiguous, 18-bit ADC and 20-bit DAC conversion rate, but present majority Codec also only can achieve bidirectional 16bit the conversion rate, this could not but make the one admire.
EP-4G4A uses ALC650
You possibly do not believe, the AC'97 sound effect chip the are very more than low-grade sounds card (even includes SB Live!) All must suitablly listen music, in particular similar ALC201A and ALC650 like this designs outstanding Codec. The domestic famous computer audio frequency website " was short žèÐÐ " once like this is the AC'97 sound effect chip rehabiliation: " If you plans other acquires together the sound card uses in to listen before the music, we intensely suggest you listen to the soft sound card which on your motherboard supplements, perhaps this soft sound card can give you one pleasantly surprised, listens when please uses one pair of good one sound box, but is not only has several ten Yuan ultra low-grade playthings. If you are using Live! Series sound card, moreover the motherboard also supplemented the AC'97 soft sound card, we similarly suggested you used this soft sound card... The AC'97 soft sound card may let you hear to a cleaner one sound, if the soft sound card used compared to Avance ALC100 this kind of upscaleer Codec, then you had to try trial one."
In under the driver unceasing optimization, the ALC650 sound effect chip already was allowed to be arrogant facing the tabletop theater system level application. We discover, coordinates WincDvd, PowercDvd and so on to have AC3, DTS decoded software before only can the audio frequency effect which only then could comprehend in the movie theater, now can penetrate ALC650 is perfect its return to original state. EP-4G4A as if is tells the numerous people " the big piece " the feeling by no means merely is belonging SB Live! The EP-4G4A AC'97 sound effect chip equally can achieve.
EP-4G4A provides SPDIF
In addition EP-4G4A also provided to the SPDIF input and the output support, this is not sees in the present motherboard. SPDIF (Sony/Philips Digital Interface) is SONY, the PHILIPS numeral audio frequency connection abbreviation. Speaking of the transmission way, SPDIF divides into the output (SPDIF OUT) and the input (SPDIF IN) two kinds. It carry on the digital audio frequency signalling through the optical fiber substitute traditional the simulated signal transmission way, therefore may obtain the high grade acoustic fidelity effect. You may with have the SPDIF connection through the audio frequency line SPDIF CD-ROM connect, because directly was the digital signal ordinary light has not driven the signal loss which performance low DAC and ADC transformed brings, this time the acoustic fidelity was good otherwise on completely is decided Yu Ni's sound box. In addition, you also may use support SPDIF the sound box (for example stroll S2.1D), connects it the SPDIF numeral output connection obtains " is pure " the acoustic fidelity.
At present, audio frequency perfect board - EPoX EP-4G4A and EP-4G4A+, already comprehensively entered each place market. " Breathes out the electricity class " the club sale on commission business and the UNIKA double sensitive electron assigns the sale on commission business place all to have the on-hand merchandise sells, the scene consultation also has more preferential benefits. Must understand more situations, the welcome registers www, unika.com.cn and www.go2pc.com.cn or sends a telegram the correlation sale on commission business.
EP-4G4A uses ALC650
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
