Op donderdag 16 mei 2002 15:00 schreef Unexplained het volgende:
Ik interesseer mij iets meer voor het stukje daarboven, eigenlijk
lol nou hier kotm het STUK daar boven, het is nogal een lap tekst komt ie:
[global]
# 1. Server Naming Options:
# workgroup = PRIVE
workgroup = PRIVE
# netbios name is the name you will see in "Network Neighbourhood",
# but defaults to your hostname
; netbios name = <name_of_this_server>
# server string is the equivalent of the NT Description field
server string = Samba Server %v
# Message command is run by samba when a "popup" message is sent to it.
# The example below is for use with LinPopUp:
; message command = /usr/bin/linpopup "%f" "%m" %s; rm %s
# 2. Printing Options:
# CHANGES TO ENABLE PRINTING ON ALL CUPS PRINTERS IN THE NETWORK
# (as cups is now used in linux-mandrake 7.2 by default)
# if you want to automatically load your printer list rather
# than setting them up individually then you'll need this
printcap name = lpstat
load printers = yes
# It should not be necessary to spell out the print system type unless
# yours is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx, cups
printing = cups
# Samba 2.2 supports the Windows NT-style point-and-print feature. To
# use this, you need to be able to upload print drivers to the samba
# server. The printer admins (or root) may install drivers onto samba.
# Note that this feature uses the print$ share, so you will need to
# enable it below.
# This parameter works like domain admin group:
# printer admin = @<group> <user>
; printer admin = @adm
# 3. Logging Options:
# this tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Put a capping on the size of the log files (in Kb).
max log size = 50
# Set the log (verbosity) level (0 <= log level <= 10)
; log level = 3
# 4. Security and Domain Membership Options:
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page. Do not enable this if (tcp/ip) name resolution does
# not work for all the hosts in your network.
; hosts allow = 10.0.0.10 10.0.0.12 127.
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
; guest account = nobody
# Security mode. Most people will want user level security. See
# security_level.txt for details.
security = user in security = share
# Use password server option only with security = server or security = domain
# When using security = domain, you should use password server = *
; password server = <NT-Server-Name>
; password server = *
# Password Level allows matching of _n_ characters of the password for
# all combinations of upper and lower case.
; password level = 8
; username level = 8
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
# Encrypted passwords are required for any use of samba in a Windows NT domain
# The smbpasswd file is only required by a server doing authentication, thus
# members of a domain do not need one.
encrypt passwords = yes
smb passwd file = /etc/samba/smbpasswd
# The following are needed to allow password changing from Windows to
# also update the Linux system password.
# NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
# NOTE2: You do NOT need these to allow workstations to change only
# the encrypted SMB passwords. They allow the Unix password
# to be kept in sync with the SMB password.
; unix password sync = Yes
; passwd program = /usr/bin/passwd %u
; passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n
;*passwd:*all*authentication*tokens*updated*successfully*
# Unix users can map to different SMB User names
; username map = /etc/samba/smbusers
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /etc/samba/smb.conf.%m
