@Home Speed patch
  • poortvliet
  • Laatst online: 21:10
Op de site http://www.speedguide.net staat onder patches ook een speed speciaal voor @home.
Is dit ook voor @home Nederland?:?
@Home Speed Patch
A lot of people reported drastic speed increase using this patch. It's a program that was supported by @Home Cable Modem Service at the beginning of 1998, and it claims to make registry changes in order to increase Cable modem performance. The only key it makes changes to, that I'm aware of is "DefaultRcvWindow". It changes it to "373360" ?! The only disadvantages that I know of, are that the program "TCPAdjust" chokes on that registry setting, and wouldn't start, and that the 373360 RWin setting seems bogus, since it is not multiple of MSS. Another fact is that such large value is not supported under Windows 95 and NT, only Windows 98, 98SE and Windows 2000 have Large TCP Windows Support. To get the last bit of performance out of your Cable Modem, I'd recommend changing the RWin setting to some multiple of MSS after applying the patch - check the Registry Tweaks section , or install one of our Generic Registry patches after applying the @Home patch .
This patch is no longer supported by the @Home staff, according to them "It might cause some problems with stream video..." If you still want it, you can download it from here. It has a nice install/uninstall program and I couldn't reproduce any problems with "video" while running the patch. If you want to uninstall this patch for some reason, you can do it easily from "Control Panel > Add/Remove Programs"
  • IceStorm
  • Laatst online: 22:41
IceStorm
This place is GoT-like!!!
VOlgens mij was die USA @home only :)
  • iznogood
Sorry kid, die gaat hier inderdaad niet werken.. ;(
Just as Good
Kan ik bevestigen: is alleen voor 1 type modem dat voornamelijk in America gebruikt word.
  • poortvliet
Okee bedankt, dan houden we het wel bij de reg!
  • Sorcerer8472
  • Laatst online: 23:33
Sorcerer8472
Mens sana?
Uhm... [topic=490588/1]
Op zaterdag 18 mei 2002 18:05 schreef Sorcerer8472 het volgende:
als een topic al bestaat en hij wordt nog een keer geopend dan wordt hij of gesloten of zakt hij (zoals nu) naar beneden...
dan moet je hem niet weer omhoog kicken met de melding naar dat andere topic.
