[PHP] Versie 4.2.1 Released
  • LuCarD
LuCarD
Certified BUFH
Voor de liefhebber.
Versie 4.2.1 is officieel released.
Windows Binary
*nix Package
Changelog
Added safe-mode checks to show_source(), parse_ini_file() and rmdir(). Also fixed security problems with safe_mode_include_dir directive. (Rasmus)
Changed HTTP upload code to accept 0 byte file uploads. (Zeev)
Major update of domxml. New functions, better DOM compliance and bug fixes:
Changed the old $node->append_child() to $node->append_sibling() since the new append_child() behaves correctly (= W3C standard).
Added domxml functions:
domxml_elem_get_elements_by_tagname()
domxml_doc_get_elements_by_tagname()
domxml_doc_get_element_by_id()
domxml_elem_remove_attribute()
domxml_elem_get_attribute_node()
Fixed a segfault in domxml_unlink().
Added formatting option to domxml_dump_mem().
(Uwe, jtate, Chregu)
Fixed a bug in socket_select() that could cause unexpected behavior when using a statement like $w = $e = array($sock); This change unfortunately prevents the use of constant values (e.g. NULL) for the socket array paramaters. Instead, use a temporary variable or an expression with the leftmost member being a temporary variable. ex.: socket_select($w, $r, $e = NULL, 10); (Jason)
Fixed crashes in the session serializer. (Stas)
Fixed malformed atime/mtime with touch(). (Yasuo)
Fixed a couple of bugs in array_sum() and array_merge(). (Andrei)
Fixed SJIS directory name handling under Windows. (Rui)
Fixed empty mb_output_handler() output when Content-Type is specified. (Yasuo)
Fixed the false logic in ext/session which made SID constant not to be defined when cookies are disabled. (Sascha)
Fixed possible crash bug in HTTP uploads. (Patch: Lucas Schroeder)
Fixed possible NULL-pointer dereferencing in the COM extension which caused 'Error in php_OLECHAR_to_char()' warnings on various places. Also modified the API to consistently return NULL in case of an error. (Alan, Harald)
Fixed a bug in the COM extension that caused outproc servers to 'hang' because of a missing Release() call. (Alan, Harald)
Programmer - an organism that turns coffee into software.
  • flat
hmmm voor mij is 't iig niet de moeite om te gaan upgraden zie ik al...
voor anderen wel?
"Happiness is a way of travel, not a destination."
--Roy Goodman
  • DRvDijk
  • Laatst online: 08-09 17:10
Misschien om array_sum & array_merge, maar daar heb ik nog niet eerder problemen mee gehad..
  • Nielsz
Nou, Grum, dat duurde ff he :P
* Grum dacht dat er binnen 4 dagen deze versie klaar zou zijn.
Dit is alleen leuk als je domxml wil gaan gebruiken denk ik.
  • LuCarD
LuCarD
Certified BUFH
Op dinsdag 14 mei 2002 09:54 schreef Flat© het volgende:
voor anderen wel?
Heee je hebt mijn icoon gejat....jij jij dief.... :( :+
btw... Is de source Code in te zien? >:)
  • flat
* flat durft die niet te laten zien, in heel P&W is niemand die zo slecht PHP't als ik :P
en daarnaast, straks loopt half GoT met 'n icon-jattend-icon rond, en dan is de herkenbaarheid helemaal weg :o
nu is 't gewoon zo van: twee bijna dezelfde icons onder elkaar? dan is de onderste post van flat© :D
--Roy Goodman
  • Dennis
  • Laatst online: 22:13
Nielsz :
*D :o
