Op de website van FluxBox lees ik dat het mogelijk is om dockapps in de slit te plaatsen, echter wat ik ook doe ik krijg geen slit en de dockapps (wmnet bv.) staan gewoon los op het scherm.
Ok.. ff naar de site van FluxBox geweest.. Was nl 30 sec werkt. Volgende tegengekomen.. misschien nuttig:
How do I use it?
Well, the first thing is to make sure that it's compiled into your copy of fluxbox. It's generally safe to assume it is; All packages for different distributions ship with it, and you have to manually turn off support for it.
Other than that, You can run any 'dockable' application. (This is also known as running in 'withdrawn' mode). As an example, xmms ships with the 'wmxmms' application. Simply run 'wmxmms -w &', and it will appear in the slit.
The popular gkrellm program also supports a -w option to allow it to run in the slit.
How do I use it?
