Ja het komt door de xinetd.conf. Heb ff gezocht op het bulletin board van de e-smith site. Kwam het volgende tegen:
ftpd is run out of xinetd on e-smith, so changing proftpd's config file will have no effect. This is a quick walkthrough of what I think are the total sum of changes required, try yourself and decide if it works, it worked for me...
Make a file /etc/e-smith/templates-custom/etc/xinetd.conf/30ftp
ie. mkdir -p /etc/e-smith/templates-custom/etc/xinetd.conf/
cp /etc/e-smith/templates/etc/xinetd.conf/30ftp \
and make the following changes (service -> unlisted, add port, add protocol, add type)
my $status = db_get_prop($confref, "ftp", "status") || "disabled";
unless ($status eq "enabled")
$OUT .= "\n";
$OUT .= "# proftpd is not enabled in the e-smith services database.";
return;
my $accessLimits = db_get_prop($confref, "ftp", "accessLimits") || "private"
if ($accessLimits eq "off")
$OUT .= "\n";
$OUT .= "# ftp access limits has been set to 'disabled entirely'\n";
$OUT .= "# in the e-smith services database.\n";
return;
$OUT .= "service proftpd\n";
$OUT .= "{\n";
$OUT .= " protocol = tcp\n";
$OUT .= " port = <substitute your port here>\n";
$OUT .= " socket_type = stream\n";
$OUT .= " wait = no\n";
$OUT .= " user = root\n";
$OUT .= " server = /usr/sbin/in.proftpd\n";
$OUT .= "}";
ie. replace that with your desired port... (make sure its not something used by another running service /etc/services)
then expand your xinetd.conf file
/sbin/e-smith/expand-template /etc/xinetd.conf
and you should have a section like
service proftpd
protocol = tcp
port = 2121
wait = no
user = root
Bij degene die daar er problemen mee had werkte deze oplossing.
Suc6.
(Volgende keer ook ff zelf zoeken op het bulletin board van e-smith Red_Head
