[php] [ftp] werkt hier wel, daar niet :(
  • 1.061 views sinds 30-01-2008
Ik heb deze code:
index.php:
PHP:
<?<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head>    <title>FTP Upload form</title><script language="JavaScript">self.resizeTo(400,500);self.scrollbars = 1;</script><link rel="stylesheet" href="http://www.horizondd.nl/style.css" type="text/css"><?include 'functions.php';$user =             'gebruikersnaam';$ftp_server =       'ftpserveradres';$ftp_dir =          '/www/naar/HTML/dir/'.$user.'/download/';$ftp_user_name =    'ftpuser';$ftp_user_pass =    'ftppass';// set up basic connection$conn_id = ftp_connect($ftp_server); // login with username and password$login_result = ftp_login($conn_id, $ftp_user_name, $ftp_user_pass); // check connectionif ((!$conn_id) || (!$login_result)) {         echo "Ftp connection has failed!";        echo "Attempted to connect to $ftp_server for user $ftp_user_name";         die;     } else {        //echo "Connected to $ftp_server, for user $ftp_user_name<br><br>";    }if( $a == 'upload' )    { uploadFile($source_file, $destination_file, $conn_id); }if ( $a == 'download' )    { downloadFile($source_file, $conn_id, $user); }?><style>    .kopje2 {        color : Black;        font : bold;    }</style></head><body style="margins: 0 0 0 0;"><table width="100%" align="center"><tr><td><form name="uploadform" method="get"><input type="Hidden" name="a" value="upload"><table><tr><td><input class="file" type="File" name="source_file"></td><td><input type="Text" name="destination_file"></td></tr><tr><td colspan="2"><input type="Submit" value="Upload File"></td></tr></form></table><br><table><tr><td class="kopje2">Files available for download:</td></tr><tr><td><?listFiles("gebruikersnaam", $conn_id, $ftp_dir);?></td></tr></table></td></tr></table></body></html>?>
ik heb het grootste deel van de HTML code eruit geript omdat die verder niet interessant is voor de php code.
functions.php:
PHP:
<?function listFiles($user, $conn_id, $ftp_dir){ftp_chdir($conn_id, $ftp_dir);//echo "current dir: ";//echo ftp_pwd($conn_id) . "<br>";$filelist = ftp_nlist($conn_id, $ftp_dir); //filelist is arrayfor ( $i = 0; $i < count($filelist); $i++ )    {    $file = explode ($ftp_dir, $filelist[$i]);        echo "<br><a href=\"index.php?a=download&amp;source_file=$file[1]\">$file[1]</a>";    }if ( count($filelist) < 2 )    { echo "<i>There are currently no downloads available.</i>"; }}function uploadFile($source_file, $destination_file, $conn_id){$source_file = stripslashes($source_file);echo "<br>current dir: ";echo ftp_pwd($conn_id);ftp_chdir($conn_id, '/www/naaruploaddir/HTML/upload');echo "<br>current dir: ";echo ftp_pwd($conn_id);// upload the file$upload = ftp_put($conn_id, $destination_file, $source_file, FTP_BINARY); // check upload statusif (!$upload) {         echo "Ftp upload has failed!";    } else {        echo "Uploaded $source_file to $ftp_server as $destination_file";    }// close the FTP stream //ftp_quit($conn_id); }function downloadFile($source_file, $conn_id, $user){$ftp_server =       'ftpservernaam';$ftp_dir =          '';$ftp_user_name =    'ftpuser';$ftp_user_pass =    'ftppass';// set up basic connection$conn_id = ftp_connect($ftp_server); // login with username and password$login_result = ftp_login($conn_id, $ftp_user_name, $ftp_user_pass); // check connectionif ((!$conn_id) || (!$login_result)) {         echo "Ftp connection has failed!";        echo "Attempted to connect to $ftp_server for user $ftp_user_name";         die;     } else {        echo "Connected to $ftp_server, for user $ftp_user_name<br><br>";    }#bool ftp_get ( resource ftp_stream, string local_file, string remote_file, int mode)echo "$conn_id<br>$source_file<br>";ftp_get ( $conn_id, "C:\\Documents And Settings\\Administrator\\Desktop\\".$source_file, "/www/padnaardownloaddir/HTML/$user/download/".$source_file, FTP_BINARY );}?>
De grap zit dus hier: op mijn localhost heb ik Apache draaien, en hier werkt het script naar behoren. Nu heb ik het op endoria gedraaid (heeft ook ftp support, ondersteunt alle functies), maar daar krijg ik zowel bij downloaden als uploaden een error in de trant van 'could not open file bestandsnaam'
Heeft iemand een idee waar dit nou weer aan kan liggen? Dit irriteert me namelijk zwaar, dit script moet ik binnenkort echt draaiende hebben.
  • D2k
  • Laatst online: 31-08 10:19
D2k
rechten?
safe mode?
Doet iets met Cloud (MS/IBM)
Op zondag 12 mei 2002 13:48 schreef D2k het volgende:
rechten?
safe mode?
kun je daar iets uiteg bij geven? Ik kan wel een beetje php typen maar wat bedoel je met de rechten?
  • Nikel
Probeer anders ook eens om direct naar het ip ipv de hostname te connecten. Ik heb eens meegemaakt dat om een of andere vage reden je vanuit php niet naar hostnames maar wel naar ips kon connecten.
Op zondag 12 mei 2002 14:21 schreef Nikel het volgende:
waar ik het script ook uitvoer, het gaat wel om dezelfde ftp server, alleen de server waar het script wordt gedraaid is verschillend. Bovendien werkt het connecten bij allebei, hij geeft op de pagina wel direkt een filelist door listFiles()
Misschien de firewall of zeg ik iets doms ?
edit : oww ja Joove zal wel gelijk hebben
  • Joove
  • Laatst online: 08:38
volgens mij is het de 'safe-mode'. Je kan dit kijken door volgende script te draaien:
PHP:
<?phpinfo();?>
Het zou kunnen zijn dat als php in safemode draait dat dan de functie is uitgeschakelt.
edit: het ligt niet aan een firewall denk ik, anders zou je niks kunnen ongeveer, en vanuit gaande dat je bestanden upload via ftp, zal die poort anders wel open staan, dus dat is het probleem niet.
Op zondag 12 mei 2002 16:47 schreef Joove het volgende:
PHP:
<?info();?>
in mijn eerste post stond dat er geen functies waren uitgeschakeld
als het wel op je localhost (of een andere server) werkt, lijkt mij dat er toch iets niet helemaal knor zit bij eudora. kijk voor de zekerheid in de phpinfo() of er geen functies uitgeschakeld zijn oid, anders zou ik maar eens een mailtje sturen naar de eudora helpdesk...
