Van de Kerio website gehaald:
My error log reports NAT:GO 'connection limit reached'. What does it mean and can it be fixed?
WinRoute allocates a maximum of 128 simultaneous connections per host on the network. Some applications, typically those using stateless protocols, will require more than the allowed 128 NAT allocations. It is possible to increase this capacity within the registry under HKLM/software/kerio/winroute. The specific value is called 'natconnlimitperhost'. Before modifying this value make sure to stop the winroute engine or the changes will not take affect. Note also that winroute's entire NAT pool has a capacity of 1600 entries. If necessary you may also increase this value up to 20,000 using the value 'NatTableSize'. It is recommended that you marginally increase these values and monitor the error log to determine a sufficient capacity.
Indien je nog een oude versie van winroute gebruikt moet je "kerio" vervangen door "tinysoftware"
