Tooltje voor LiteOn 32x & 40x brander !!
  • hjs
kwam ik tegen op het forum van cdrlabs.com
These tools will:
1: Show what speed your writer will write this media at(which speed smartburn selects for your media).
2: Show the CD-R disc manufacturer, DYE type and CD length.
For 40125S and 40125W:
http://www.liteonit.com.tw/ZIP/SBMC40.zip
For 32123S and 32125W:
http://www.liteonit.com.tw/ZIP/SBMC32.zip
  • hjs
Had de link even naar een collega gemaild welke thuis niks had te doen, zijn antwoord.
Maar ffe dat proggie... Heb een zooitje ceedees getest, hier de
resultaten.
Philips Ceedee
This Disc is designed for CD-RW/COMBO Drive Only.
Disc Type, Material = CD-R, Cyanine
ATIP Lead-in = 97m 15s 12f
Norminal Capacity = 702.83MB (79m 59s 74f)
Disc Manufacturer maybe = RiTEK,H,K
SMART-BURN Speed Limit = 24X
Infinity Black Ceedee
Disc Type, Material = CD-R, Phthalocyanine
ATIP Lead-in = 97m 16s 06f
Disc Manufacturer maybe = Memorex Black
Liteon Ceedee
ATIP Lead-in = 97m 15s 17f
Norminal Capacity = 702.83MB (79m 59s 73f)
Disc Manufacturer maybe = RiTEK,J
SMART-BURN Speed Limit = 32X
Liteon CdRw Ceedee
Disc Type, Material = HSCD-RW, Phase Change
ATIP Lead-in = 97m 26s 65f
Norminal Capacity = 658.89MB (75m 00s 00f)
Disc Manufacturer maybe = CMC
SMART-BURN Speed Limit = 12X
Philips Oude Ceedee
ATIP Lead-in = 97m 24s 01f
Norminal Capacity = 656.40MB (74m 43s 00f)
Disc Manufacturer maybe = Taiyoyuden,P Dye
SMART-BURN Speed Limit = 16X
Philips Nieuwe Ceedee
ATIP Lead-in = 97m 26s 66f
Disc Manufacturer maybe = CMC,Imation
Philips Oude Cdrw Ceedee
Disc Type, Material = CD-RW, Phase Change
ATIP Lead-in = 97m 24s 60f
Norminal Capacity = 657.42MB (74m 50s 00f)
Disc Manufacturer maybe = Unknown
SMART-BURN Speed Limit = 4X
TDK Ceedee
Daarom kan Nero vaak maar 24 speed branden!
Thanx!
  • itsme
Werkt dat ook op een 24x liteon? En zo niet, werkt t wel als ik m "upgrade" naar 32x???
"If God wanted us to have unlimited free energy He would have put a giant fusion reactor in the sky"
  • Stropdas
  • Laatst online: 04-09 16:22
Stropdas
Insert subtitle here
Op vrijdag 10 mei 2002 14:26 schreef bas_konings het volgende:
Je kan altijd testen of het werkt :) Hij kan misschien alleen niet aangeven dat een CD sneller dan 24x aankan
Honda VFR800fi '99 | Volvo S60 '04
  • hjs
Het schijnt te werken op:
LiteOn 24x
en nog andere niet Liteon drivers
check www.cdfreaks.com en het forum van www.cdrabs.com
  • Metten
  • Registratie: September 1999
  • Laatst online: 04-09 13:21
Metten
ik hou het graag simpel
Hetzelfde als die nieuwe philips van HJS dus, maar dit was een Sunstar van 50 eurocent (incl. jewelcase)
  • Turismo
  • Laatst online: 12-09 11:26
hehehe me tdk 16x geven dit aan
        ATIP Lead-in = 97m 25s 07f
     Norminal Capacity = 702.69MB (79m 59s 00f)
 Disc Manufacturer maybe = MPO,France
beters, want ik heb er een stuk of 50 van
en ik heb een 32x brander
Gamebak Look Behind you, a Three Headed Monkey!
  • The Dolf
Blijkt niet erg goed te werken met mijn lite-on 48125W (was 32x)
een 24x dynabyte 90 min getest
ATIP Lead-in = 97m 00s 06f
Gezocht!
Samsung 1TB HD103SI printplaat
Router
If everything seems to be going well, you have obviously overlooked something
  • Flipmo2K
Op maandag 10 juni 2002 20:32 schreef thedolf het volgende:
Maar hoezo werkt 'ie niet goed dan? Omdat je 24x cd's hebt die 32x aankunnen? Dat komt wel vaker voor hoor, niks om je druk over te maken.
  • The Dolf
Op dinsdag 11 juni 2002 06:57 schreef Flipmo2K het volgende:
Nee. Omdat ik een 90min cd heb en hij geeft maar 80min aan. ff voor de duidlijkheid, de brander ondersteund officieel 90min cd's
Gezocht!
Router
  • ph03nix80
  • Laatst online: 06-08 11:12
m'n Trax-data ceedees van 80 min:
Disc Manufacturer maybe = RiTEK,G
cheap-ass ceedees bij de mediamarkt gekocht voor 1,99 per 10
ATIP Lead-in = 97m 28s 26f
Norminal Capacity = 654.49MB (74m 30s 00f)
Disc Manufacturer maybe = KingPro
SMART-BURN Speed Limit = 40X
  • maspro
Nou wat een geweldig proggie, ik heb ff een Memorex cd en de bij mijn brander geleverde LiteOn cdrw-tje getest en dit was de uitkomst :? :
This Disc is designed for Unknown
Disc Type, Material = Unknown
ATIP Lead-in = Unknown
Norminal Capacity = Unknown
SMART-BURN Speed Limit = Unknown
En dit terwijl op hun site Memorex wel als aangeraden media staat. En dat hun eigen meegeleverde cdrw niet eens herkent wordt vindt ik helemaal slecht. :( btw ik heb firmware XS0X.
  • The Dolf
Net mijn Imation cd getest met hun 48x tooltje
 Disc Manufacturer maybe = CMC(99min)
  SMART-BURN Speed Limit = 48X
Gezocht!
Router
  • Montana
  • Laatst online: 21:34
Montana
Apple and X-H2 ..what else !
Aldi cd's uit Duitsland
10 stuks 80 min 5 euro merk Tevion (MAX 24 SPEED)
Ik heb hiervan al paar honderd van gebrandt.
Gegevens volgens Liteon Progje:
ATIP Lead-in = 97m 32s 19f
Disc Manufacturer maybe = Prodisc
Apple Studio Max M2 and Apple Studio Display | Macbook Air 15" M2 | FUJIFILM X-H2 | XF200 F2 | XF1.4x TC F2 |XF 2xTC | XF500 f5.6 | XF150-600 | XF80 | XF16-80 | Viltrox 27mm f1.2 PRO X-Mount
  • The Dolf
Op zaterdag 15 juni 2002 20:05 schreef Montana het volgende:
Met welk programma heb je dat getest?
Gezocht!
Router
  • Wierdo_NL
  • Laatst online: 07-09 21:40
Op zaterdag 15 juni 2002 20:19 schreef thedolf het volgende:
Met de proggies die bovenaan het topic in een linkje staan.
http://www.liteonit.com.tw/ZIP/SBMC48.zip voor de "48x" Lite-on brander :)
There is a fine line between hobby and mentaldisorder
  • Xandrios
  • Laatst online: 11-09 12:51
op m'n 48 x 12 x 48 draait het prog ook :)
Wel vreemd dat ie altijd aangeeft: smart-burn limit: 40x
terwijl ik met nero (smart burn=on) gewoon prima op 48x kan fikken...
Mischien omdat ik het prog voor de 40x brander gedownload heb ;)
Dit zegt ie van m'n 32x Platinum cedees:
ATIP Lead-in = 97m 27s 66f
Disc Manufacturer maybe = RICOH
Wel vreemd, van een paar oude 16x platinums zegt ie:
'K heb nu een nieuwe brander, maar mijn oude acer heeft met die Ricoh cedees heel wat meer moeite dan met de Kingpro *D
Maar de lite-on die ik nu heb pakt de Ricoh's perfect. Wel jammer dat ik geen lege Kingpro's meer heb om te bakken met de lite-on ;(
[edit]
Disc Manufacturer maybe = Taiyoyuden,Tuned-X
Gebruikt Taiyo Yuden een andere basisstof voor de cd's ?
Cyanine ipv Phthalocyanine :?
  • Wierdo_NL
Bij mijn 32x@48x Lite-on zegt ie dat ie netjes de 32x Platinum CD's op 48x kan branden >:)
Dus ik ben super blij met zowel de CD's als de Brander >:)
  • Xandrios
Op zaterdag 15 juni 2002 20:29 schreef Wierdo_NL het volgende:
Welke fabrikant heeft die 32x platinums gemaakt :?
Bij mij zegt ie max 40x namelijk ;(
  • Wierdo_NL
Op zaterdag 15 juni 2002 20:33 schreef Cutebritney het volgende:
ah ik zie het al :
Disc Manufacturer maybe = RiTEK,JS
echt shit... toen ik had gelezen dat je 32z12x40 kon overlockcne naar 48x12x48 had ik die gelijk gehaald maar nu ziei k dat ze de verkeerde heb... ik eb de 12321s of zoiets :'(
  • Xandrios
Op zaterdag 15 juni 2002 20:34 schreef Wierdo_NL het volgende:
ah ik zie het al :
Damn, Ritec :D
Heb ik waarschijnlijk net een verkeerde partij cdr's te pakken gekregen ;)
Waren ook wel erg goedkoop :P (45 cent P/s inc. Jewelcase)
  • Wierdo_NL
Op zaterdag 15 juni 2002 20:36 schreef TristanOptereon het volgende:
Ook de S versie schijnt hoger te kunnen dan dat ie denkt :)
Tja, heb ik misschien gewoon mazzel gehad :)
32x is al rap zat.
  • Xandrios
Op zaterdag 15 juni 2002 20:38 schreef Wierdo_NL het volgende:
de 24x versie ja ;) (naar 32x)
De 32x versie kun je toch niet oc-en :?
Good enough for me.
Trouwens 40x LiteOn voor € 86 :) :)
  • The Dolf
Op zaterdag 15 juni 2002 20:53 schreef Gregole het volgende:
Ik heb een 48x voor €77
Gezocht!
Router
  • Xandrios
Op zaterdag 15 juni 2002 21:36 schreef thedolf het volgende:
* Xandrios een 48x voor 71.50 :9
nouja, 't was een 32x ;)
Op zaterdag 15 juni 2002 21:36 schreef Cutebritney het volgende:
/me een 48x voor 71.50 :9
Nah... bij mediamarkt was die 40x €179!
  • The Dolf
Op zaterdag 15 juni 2002 23:07 schreef Gregole het volgende:
Maar wie koopt er nou een 40x als zelfs een 32x sneller werkt?
Gezocht!
Router
Op zaterdag 15 juni 2002 23:10 schreef thedolf het volgende:
Wat maakt het eigenlijk uit, die paar seconden, als we het toch over snelheid hebben ??
  • The Dolf
Op zaterdag 15 juni 2002 23:12 schreef Gregole het volgende:
Dan snap ik helemaal niet waarom je een 40x zou kopen.
Gezocht!
Router
