Heej tweakers,
Wie kan mij helpen? D.m.v. een script wil ik graag de ODBC instellen.
Hij werkt echter perfect, ik kom echter maar niet uit 2 dingen.
1. Hoe kan ik de ODBC koppeling d.m.v. dit script automatisch een password meegeven.
2. Hoe kan ik er voor zorgen dat ook het keuzerondje van de vraag "How should SQL server verify the authenticity of the login" Wordt ingestel op "with SQL server login"
Hieronder het script: (helaas is van de tabs
weinig overgebleven, ik kan hem altijd ff mailen)
;Plaatsen ODBC settings t.b.v. test database
WRITEPROFILESTRING ("c:\windows\odbc.ini","ODBC 32 bit Data Sources","SICS 2.6 TEST","SQL Server (32 bit)")
WRITEPROFILESTRING ("c:\windows\odbc.ini","SICS 2.6 TEST","Driver32","C:\WINDOWS\SYSTEM\sqlsrv32.dll")
ADDKEY ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources","SICS 2.6 TEST","SQL Server","REG_SZ")
ADDKEY ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 TEST")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","Driver", "C:\\WINDOWS\\SYSTEM\\sqlsrv32.dll","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","Description","SICS 2.6 TEST","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","Server","10.9.200.85","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","Database","SICS_TST","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","LastUser","SICSNT","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","pw","SICSNT","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\SICS 2.6 Test","Trusted_Connection","Yes","REG_SZ")
ADDKEY ("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\Client\ConnectTo")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\Client\ConnectTo","10.9.200.85","DBMSSOCN,10.9.200.85,1433","REG_SZ")
ADDKEY ("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\Client\TDS")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\Client\TDS","10.9.200.85","7.0","REG_SZ")
; KiX script voor updaten van BO Cliënt
; om te connecten met BO database
; 03-05-2000 door WJS
; versie 2.0
WRITEPROFILESTRING ("c:\windows\odbc.ini","ODBC 32 bit Data Sources","BO TestOmgeving","SQL Server (32 bit)")
WRITEPROFILESTRING ("c:\windows\odbc.ini","BO TestOmgeving","Driver32","C:\WINDOWS\SYSTEM\sqlsrv32.dll")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources","BO TestOmgeving","SQL Server","REG_SZ")
ADDKEY ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","Driver","C:\\WINDOWS\\SYSTEM\\sqlsrv32.dll","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","Description","BO TestOmgeving","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","Server","10.9.200.85","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","Database","SICS_TST","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","LastUser","SICSNT","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","pw","SICSNT","REG_SZ")
WRITEVALUE ("HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\BO TestOmgeving","Trusted_Connection","Yes","REG_SZ")
Ik hoop dat iemand mij kan helpen!!
Alvast bedank!
; versie 2.0
Alvast bedank!
