Hi,
Kzit met het volgende:
Ik probeer de capture mogelijkheden te gebruiken van de all in wonder radeon onder linux (SUSE 8.0). Nu heb ik die module (gatos) en compileerd wel maar met een paar fouten. Is er iemand die hier ervaring mee heeft ??
De Fout ->
km_api.c: In function `add_km_device':
km_api.c:101: warning: int format, long int arg (arg 3)
km_api.c:103: warning: int format, long int arg (arg 3)
km_api.c: In function `init_module':
km_api.c:141: warning: unused variable `i'
km_api.c:140: warning: unused variable `result'
km_api.c: At top level:
km_api.c:37: warning: `expand_buffer' defined but not used
km_api.c:139: warning: `init_module' defined but not used
Als ik vervolgens de modules wil laden krijg ik het volgende:
./km.o: unresolved symbol mach64_km_irq
./km.o: unresolved symbol cleanup_km_v4l
./km.o: unresolved symbol radeon_is_capture_active
./km.o: unresolved symbol radeon_get_window_parameters
./km.o: unresolved symbol mach64_get_window_parameters
./km.o: unresolved symbol rvfree
./km.o: unresolved symbol rage128_start_transfer
./km.o: unresolved symbol mach64_start_transfer
./km.o: unresolved symbol rage128_allocate_single_frame_buffer
./km.o: unresolved symbol init_km_v4l
./km.o: unresolved symbol mach64_is_capture_active
./km.o: unresolved symbol mach64_stop_transfer
./km.o: unresolved symbol rage128_is_capture_active
./km.o: unresolved symbol radeon_km_irq
./km.o: unresolved symbol radeon_start_transfer
./km.o: unresolved symbol mach64_allocate_single_frame_buffer
./km.o: unresolved symbol rage128_get_window_parameters
./km.o: unresolved symbol rage128_km_irq
./km.o: unresolved symbol radeon_stop_transfer
./km.o: unresolved symbol radeon_allocate_single_frame_buffer
./km.o: unresolved symbol rage128_stop_transfer
en doet vervolgens niets meer.
HEEELP,
Bvd Sander
De Fout ->
HEEELP,
Bvd Sander
