Apache problemen
  • jlokerse
  • Laatst online: 11-08-2021
Hi,
nadat ik gisteren heb gespeeld met beveiliging onder apache m.b.v. .htaccess bestanden, kom ik nu niet meer op mijn website.
Ik heb een RH 7.2 server op mijn lan.
Ik heb in 2 dirs een .htaccess file gezet maar kan nu zelf de root niet eens benaderen.
Zag wel dit in mijn logfile :
192.168.1.80 - - [02/May/2002:10:50:16 +0200] "GET /warroom/images/title_configuration.gif HTTP/1.1" 200 806
213.211.100.55 - - [02/May/2002:10:54:33 +0200] "GET /scripts/root.exe?/c+dir HTTP/1.0" 404 278
213.211.100.55 - - [02/May/2002:10:54:34 +0200] "GET /MSADC/root.exe?/c+dir HTTP/1.0" 404 276
213.211.100.55 - - [02/May/2002:10:54:36 +0200] "GET /c/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.211.100.55 - - [02/May/2002:10:54:37 +0200] "GET /d/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 286
213.211.100.55 - - [02/May/2002:10:54:39 +0200] "GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.211.100.55 - - [02/May/2002:10:54:40 +0200] "GET /_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.211.100.55 - - [02/May/2002:10:54:42 +0200] "GET /_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 317
213.211.100.55 - - [02/May/2002:10:54:43 +0200] "GET /msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 333
213.211.100.55 - - [02/May/2002:10:54:48 +0200] "GET /scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.211.100.55 - - [02/May/2002:10:54:50 +0200] "GET /scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.211.100.55 - - [02/May/2002:10:54:51 +0200] "GET /scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.211.100.55 - - [02/May/2002:10:54:53 +0200] "GET /scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 299
213.211.100.55 - - [02/May/2002:10:54:55 +0200] "GET /scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.211.100.55 - - [02/May/2002:10:54:56 +0200] "GET /scripts/..%%35c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 283
213.211.100.55 - - [02/May/2002:10:54:58 +0200] "GET /scripts/..%25%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
213.211.100.55 - - [02/May/2002:10:54:59 +0200] "GET /scripts/..%252f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 300
192.168.1.80 - - [02/May/2002:11:16:06 +0200] "GET /idiotpage/youare.swf HTTP/1.1" 404 294
192.168.1.80 - - [02/May/2002:11:17:39 +0200] "GET /idiotpage HTTP/1.1" 403 287
192.168.1.80 - - [02/May/2002:11:18:38 +0200] "GET /idiotpage/ HTTP/1.1" 403 288
192.168.1.80 - - [02/May/2002:11:18:48 +0200] "GET /idiotpage/test.html HTTP/1.1" 403 297
192.168.1.80 - - [02/May/2002:11:19:01 +0200] "GET / HTTP/1.1" 403 278
Ben ik nu gehacked of heb ik het gewoon zelf verpest.
Ik zie geen rare users in mijn passwd file.
wat ik graag wil is een tip waar ik moet zoeken.
  • banaan-X
Dat is dus zo'n worm die hoopt dat je een ISS server draaide... Die dingen komen hier ook nog dagelijks langs (in grote getale zelfs)...
  • DaFearLess
Het moet toch aan die .htacces files liggen want die meldingen heb ik ook dagenlijks.
post die .htacces file is mischien zien wij wat er evt niet goed aan is?
specs : http://specs.tweak.to/7435
  • jlokerse
Maar wel heel toevallig dat ik nu niet meer op mijn website kom.
Ben nog steeds o pzoek naar de reden daarvoor.
  • DaFearLess
wat staat er in je error_log (Volgens mij laat je daar de acces.log zien? ) ?
  • Bart B
  • Laatst online: 06-04 17:55
.htaccess is de schuldige.... Die melding heb ik ook nog heel vaak in me logboek.
Wat bedoel je met "kom ik nu niet meer op mijn website.".
Bedoel je dat je wel een inlog scherm krijgt, maar dat hij je password niet accepteerd. Of bedoel je dat je b.v. een server error krijgt ??
  • jlokerse
hierbij de .htaccess file :
AuthName "phpadmin"
AuthType Basic
AuthUserFile /usr/local/apache/conf/users
require valid-user
en de access_log (gedeeltelijk, sorry groot stuk):
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
[Thu May  2 00:40:29 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:40:29 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:40:31 2002] [error] [client 192.168.1.80] user jeroen: authentication failure for "/phpmyadmin/index.php": password mismatch
[Thu May  2 00:40:33 2002] [error] [client 192.168.1.80] user jeroen: authentication failure for "/phpmyadmin/index.php": password mismatch
[Thu May  2 00:40:57 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:40:57 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:41:01 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 00:41:02 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 00:41:02 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 00:41:02 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 00:41:02 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 00:41:06 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 00:41:12 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 00:41:12 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 00:41:12 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 00:41:12 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 00:41:14 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:41:14 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:41:16 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:41:16 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:41:18 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:41:18 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:47:10 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:47:10 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:47:13 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: unknown require directive:"valid user"
[Thu May  2 00:47:13 2002] [error] [client 192.168.1.80] access to /phpmyadmin/index.php failed, reason: user jeroen not allowed access
[Thu May  2 00:50:11 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 00:50:12 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 00:50:12 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 00:50:12 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 00:50:12 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 09:22:24 2002] [error] [client 151.198.245.50] Invalid URI in request GET x HTTP/1.0
[Thu May  2 10:27:19 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 10:27:19 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 10:27:19 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 10:27:19 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 10:27:19 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 10:28:17 2002] [error] [client 192.168.1.80] user jeroen: authentication failure for "/test/": password mismatch
[Thu May  2 10:28:28 2002] [error] [client 192.168.1.80] user jeroen: authentication failure for "/test/": password mismatch
[Thu May  2 10:28:57 2002] [error] [client 192.168.1.80] user jeroen: authentication failure for "/test/": password mismatch
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/folder.gif
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/lastpost.gif
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/online.gif
[Thu May  2 10:47:52 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/red_folder.gif
[Thu May  2 10:47:53 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/newtopic.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/poll.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/dot_folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/lastpost.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/red_folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/hot_red_folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/hot_folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/lock_folder.gif
[Thu May  2 10:48:01 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:48:03 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:48:03 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/newtopic.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/star.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/reply.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/poll.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/quote.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/edit.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/email.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/report.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/site.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/find.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/u2u.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/ip.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/profile.gif
[Thu May  2 10:48:04 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:48:09 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:48:09 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:48:09 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:48:12 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:48:12 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:48:12 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:48:22 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:48:22 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:48:22 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:49:54 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:49:54 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:49:54 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/reply.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/poll.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/newtopic.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/star.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/quote.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/report.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/profile.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/email.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/edit.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/site.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/find.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/u2u.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/ip.gif
[Thu May  2 10:49:56 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_dw.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/boardheader.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/dot_folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/poll.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/newtopic.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/lastpost.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/red_folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/hot_red_folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/hot_folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/lock_folder.gif
[Thu May  2 10:49:57 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/xmb/images/xmbforum/arrow_up.gif
[Thu May  2 10:54:33 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/root.exe
[Thu May  2 10:54:34 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/MSADC/root.exe
[Thu May  2 10:54:36 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/c/winnt/system32/cmd.exe
[Thu May  2 10:54:37 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/d/winnt/system32/cmd.exe
[Thu May  2 10:54:39 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..%5c../winnt/system32/cmd.exe
[Thu May  2 10:54:40 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/_vti_bin/..%5c../..%5c../..%5c../winnt/system32/cmd.exe
[Thu May  2 10:54:42 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/_mem_bin/..%5c../..%5c../..%5c../winnt/system32/cmd.exe
[Thu May  2 10:54:43 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/msadc/..%5c../..%5c../..%5c/..Á../..Á../..Á../winnt/system32/cmd.exe
[Thu May  2 10:54:48 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..Á../winnt/system32/cmd.exe
[Thu May  2 10:54:51 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..À¯../winnt/system32/cmd.exe
[Thu May  2 10:54:53 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..Áœ../winnt/system32/cmd.exe
[Thu May  2 10:54:58 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..%5c../winnt/system32/cmd.exe
[Thu May  2 10:54:59 2002] [error] [client 213.211.100.55] File does not exist: /usr/local/apache/htdocs/scripts/..%2f../winnt/system32/cmd.exe
[Thu May  2 11:16:06 2002] [error] [client 192.168.1.80] File does not exist: /usr/local/apache/htdocs/idiotpage/youare.swf
[Thu May  2 11:19:01 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:19:07 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:19:14 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:19:21 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:21:56 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:22:19 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 11:22:19 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 11:22:19 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 11:22:19 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 11:22:19 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 11:22:29 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:23:32 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 11:23:32 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 11:23:32 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 11:23:32 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 11:23:32 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 11:23:34 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:23:35 2002] [crit] [client 192.168.1.80] (13)Permission denied: /usr/local/apache/htdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Thu May  2 11:23:56 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 11:23:57 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 11:23:57 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 11:23:57 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 11:23:57 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Thu May  2 11:24:34 2002] [notice] caught SIGTERM, shutting down
[Thu May  2 11:26:49 2002] [alert] httpd: Could not determine the server's fully qualified domain name, using 192.168.1.6 for ServerName
[Thu May  2 11:26:49 2002] [notice] Apache/1.3.22 (Unix) PHP/4.1.0 AuthMySQL/2.20 configured -- resuming normal operations
[Thu May  2 11:26:49 2002] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Thu May  2 11:26:49 2002] [notice] Accept mutex: sysvsem (Default: sysvsem)
De errors over die xmb images klopt das ander probleem.
Lijkt er toch een beetje op dat de .htaccess file sproblemen geven.
Heb in de httpd.conf file wel weer de parameter
AllowOverride op none gezet nadat ik 'm gisteren op AuthConfig had gezet voor de .htaccess files.
dang typo's
Op donderdag 02 mei 2002 13:48 schreef Bart B het volgende:
Jajaja :?
Die meldingen zijn gewoon meldingen van IIS wormen. Heeft niks met .htaccess te maken.
Eerlijk gezegd is boventaande errorlog duidelijk genoeg en moet je wel kunnen weten waar je de fout moet zoeken.
  • jlokerse
Sorry,
was een beetje onvolledig.
Ik heb in een subdir van mijn documentroot (phpmyadmin)
een .htaccess file gepplaatst.
Deze werkte gisteren toen ik em testte.
Daarna niks meer gedaan op de site.
Vanochtend probeerde ik wat te bekijken op de site en kom nu nergens bij dus niet de beveiligde sub dir alleen maar ook gewoon de root.
De error is :
Forbidden
You don't have permission to access / on this server.
Apache/1.3.22 Server at 192.168.1.6 Port 80
Iemand enig idee ?
Lees je .htacces nu eens door en lees dan die log eens door en vertel mij wat je opvalt!
  • jlokerse
Op donderdag 02 mei 2002 14:08 schreef Nelske het volgende:
Mij valt niks op.
ik zie wel een melding over het niet kunnen lezen van een file.
Gezien het feit dat de enige .htaccess file in mijn sub dir phpmyadin staat en ik de root niet eens kan benaderen.
Verder het feit dat de users file in mijn conf dir naar 777 gechmod is en dat in httpd.conf de allowoverride op none staat snap ik echt niet dat alles niet benaderbaar is.
Op donderdag 02 mei 2002 14:14 schreef jlokerse het volgende:
Mij valt niks op.
Begrijp je deze regel ook niet ?
Lijkt me duidelijk. De user waaronder de webserver draait (is meestal nobody) heeft geen toegang tot .htaccess
En kijk, zoals Nelske al zei, ook de inhoud van .htaccess na, dat is ook niet helemaal in orde.
  • jlokerse
Ok,
we begrijpen elkaar dus niet.
Ik stel de vraag anders :
Ik heb alle .htaccess files gewist.
Ik heb de httpd.conf in de oude staat terug gebracht.
(allowoverride none)
Ik heb de users file gewist.
en nog steeds kom ik niet op de site.
Als ik http://192.168.1.5 doe krijg ik dus : Forbidden
correct me if i'm wrong maar als ik dit heb :
\test
\blabla
\neuzel + .htaccess
is toch alleen de dir neuzel beschermd en niet alles ?
  • jlokerse
Op donderdag 02 mei 2002 14:41 schreef epauli het volgende:
De inhoud is (weliswaar overgetyped met een later gecorrigeerd typfoutje) van de doucmentatie van www.apache.org.
Lijkt me niet fout...
  • Stormtrooper
  • Laatst online: 15:25
Stormtrooper
Stormtroopers Of Death
[quote]Op donderdag 02 mei 2002 13:54 schreef jlokerse het volgende:
AuthName "phpadmin"
AuthType Basic
require valid-user
kun je van die laatste regel niet beters iets maken als:
require user <username>
Ik heb er niet zo heel veel verstand van, maar kijk eens naar:
http://httpd.apache.org/docs-2.0/mod/mod_auth_ldap.html#reqvaliduser
Stormtroopers toys: Asus Strix 16, Samsung S24 Ultra, HP Z4 G4, HP Z1 G1i, BMW R1300 GS Adv ASA.
  • jlokerse
[quote]
Op donderdag 02 mei 2002 16:24 schreef Stormtrooper het volgende:
AuthName "phpadmin"
AuthType Basic
require valid-user
is een goede optie, heb met de gedachte gespeeld.
Was de volgende stap.
Maar probleem is : alles gewist/terug gewijzigd en nog steeds geen toegang !!!!
HELP !!!!
  • Stormtrooper
Stormtrooper
Waarom wordt hier regelmatig gepost, kijk eens hier en kijk eens daar, lijkt me voor de hand liggend. Hij komt er echt niet uit, geef dan gewoon een oplossing in plaats van alleen maar te zeggen dat je het zo moet kunnen zien.
Sorry hoor, wel heel makkelijk te zeggen dat het simpel is, maar zo krijgt hij nooit zijn oplossing.
  • Stormtrooper
Stormtrooper
Jeroen,
heb je al een hier gezocht op .htaccess in inhoud
Er zijn meer postings geweest met diverse probs...
Misschien dat er eentje bij staat die je weer wat verder helpt....
Ik zou je graag helpen, maar ik ga zo lekker naar huis en ik weet niet of het vanavond gaat lukken, maar als het lukt zoek ik wel ff mee....
  • Stormtrooper
Stormtrooper
waarbij ik ook vind dat het vreemd is dat als je alles weer terug bij af hebt gezet, het nog niet werkt, maar misschien dat er nog iemand is die dit mee heeft gemaakt. Ik probeer ff te kijken en will let you know....
  • jlokerse
Gevonden,
bij het testen van de optie met het werken met .htaccess files had ik een subdir aangemaakt om te testen in mijn documentroot.
Deze had ik als root aangemaakt wat niet werkte en dus ge chmod, hierbij is waarschijnlijk is fout gegaan en de dir die als documentroot dienst doet veranderd.
Nu heb ik deze veranderd en werkt het weer.
Kan iemand a.u.b. ff posten welke rechten deze standaard heeft ?
Iedereen bedankt voor zijn inzet.
