How to prepareDIVX (with VirtualDub?) for Premiere
  • 55 views sinds 30-01-2008
Iedereen zijn engels is toch voldoende he? (anders moet ik het weer in het nl gaan overtypen)
I have a DIVX movie with this specifications
Video
Frame size (us per frame): 512 x 272
FPS: 29.970 (33367us)
# of frames (time): 204434 (1:53:41)
Decompressor: Divx :-) MPEG-4 Low Motion
Number of keyframes: 682
Min/avg/max/total key frame size: 687 / 8844 / 25122 (5891k)
Min/avg/max/total delta frame size: 70 / 2995 / 42147 (587991k)
Audio
Sampling rate: 48000
Channels: 2 (stereo)
Sample precision: 0-bit
Compression: Frau IIS Mpeg Layer 3 codec
Preload skew: 0 samples (0.00s)
# of frames: 7049
Min/avg/max/total frame size: 14911 / 15485 / 15919 (106602 k)
I want to edit this in Premiere 6.0 and after that, put it on videotape. I think it should be possible to prepare it in a format with wich Premiere can work, probably with VirtualDub. I have Virtual Dub 1.4, only I don't know how to set the specifications for filter, compression etc.
I'm used to work with the DV500 from Pinaccle, with it's format Pinnacle DV Pal
720 - 576
25 fps
25 mbit/s
PAR D1/DV PAL (1.067)
but i should be able to work with one of the other formats as well
You can also see my specifications here: http://oneman.50megs.com/images/index.html
Anybody can help me?
  • Jag
  • Laatst online: 09-10 15:36
Jag
Ja daaag. Een beetje een bericht copy/pasten dat je ook in een ander forum hebt gepost en dan niet eens de moeite nemen om het te vertalen. En dan ook nog twee keer posten ook.
