[Dreamweaver] _notes voorkomen/setting?
  • 44 views sinds 30-01-2008
Tot zover ik gezcoht heb in de setting van Dreamweaver Ultradev. kan ik nergens iets vinden om het maken van de _notes directory dat dreamweaver automatisch doet uit te schakelen weet iemand dit of dit mogelijk is ? Vraag me af waarom die notes nuttig zijn,ik vind ze lastig.. hoe te disablen ?
  • OzBoz
  • Laatst online: 19:36
OzBoz
.:.H.:.I.:.P.:.
Als het bij Dreamweaver in de Help staat zal het bij ultradev waarschijnlijk niet anders zijn:
Saving file information in Design Notes
You can create a Design Notes file for each document or template in your site. (Note that if you add Design Notes to a template, the documents created with the template do not inherit the Design Notes.) You can also create Design Notes for applets, ActiveX controls, images, Flash movies, Shockwave objects, and image fields in your documents.
To set up Design Notes for your site:
Choose Site > Define Sites, select a site, and click Edit.
In the Category list at the left, click Design Notes.
Enable Design Notes for your site by selecting Maintain Design Notes (if it's not already selected).
When Maintain Design Notes is selected, you can create Design Notes for files in your site. Whenever a file is copied, moved, renamed, or deleted, the associated Design Notes file is also copied, moved, renamed, or deleted.
Choose whether the Design Notes associated with your site are uploaded with the rest of your documents, by selecting or deselecting Upload Design Notes for Sharing.
When Upload Design Notes for Sharing is selected, you can share Design Notes with the rest of your team. When you put or get a file, Dreamweaver automatically puts or gets the associated Design Notes file. If you work alone on your site, you can deselect this option to improve performance of file transfers; when the option is deselected, Design Notes are maintained locally but are not uploaded with your files.
Click OK.
My Fizion | My 3D prints | LinkedIn
  • Pelle
  • Laatst online: 23:47
Pelle
Warezhelp: verder kijken dan je neus lang is.
OzBoz: thnks :)
