[JS] variabelen opslaan+uitlezen
volgende code:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
<html>
<head>
<title> Vlag op kaart <test> </title>
<style type="text/css">
div{font-family:tahoma; font-size:8pt; color:gray; padding:3;}
</style>
<script language="javascript" src="src/dynobject.js"></script>
<script language="javascript" src="src/dynevents.js"></script>
<script language="javascript" src="src/dragdrop.js"></script>
<script>
function Cookie(document, name, hours, path, domain, secure) {
    this.$document = document;
    this.$name = name;
    if (hours)
      this.$expiration = new Date((new Date()).getTime() + hours*3600000);
    else this.$expiration = null;
    if (path) this.$path = path; else this.$path = null;
    if (domain) this.$domain = domain; else this.$domain = null;
    if (secure) this.$secure = true; else this.$secure = false;
function _Cookie_store()
    var cookieval = "";
    for(var prop in this) {
      if ((prop.charAt(0) == '$') || ((typeof this[prop]) == 'function'))
      continue;
      if (cookieval != "") cookieval += '&';
      cookieval += prop + ':' + escape(this[prop]);
var cookie = this.$name + '=' + cookieval;
    if (this.$expiration)
      cookie += '; expires=' + this.$expiration.toGMTString();
    if (this.$path) cookie += '; path=' + this.$path;
    if (this.$domain) cookie += '; domain=' + this.$domain;
    if (this.$secure) cookie += '; secure';
    this.$document.cookie = cookie;
function _Cookie_load()
    var allcookies = this.$document.cookie;
    if (allcookies == "") return false;
    var start = allcookies.indexOf(this.$name + '=');
    if (start == -1) return false;
    start += this.$name.length + 1;
    var end = allcookies.indexOf(';', start);
    if (end == -1) end = allcookies.length;
    var cookieval = allcookies.substring(start, end);
    var a = cookieval.split('&');
    for(var i=0; i < a.length; i++)
      a[i] = a[i].split(':');
    for(var i = 0; i < a.length; i++) {
      this[a[i][0]] = unescape(a[i][1]);
    return true;
function _Cookie_remove()
    var cookie;
    cookie = this.$name + '=';
    cookie += '; expires=Fri, 02-Jan-1970 00:00:00 GMT';
new Cookie();
Cookie.prototype.store = _Cookie_store;
Cookie.prototype.load = _Cookie_load;
Cookie.prototype.remove = _Cookie_remove;
var flgCoords = new Cookie(document, "xcoor_ycoor", 240);
flgCoords.xcoor = ""
flgCoords.ycoor = ""
document.attachEvent('onload', 'startMe()');
var layer1, layer2;
function startMe() {
layer1 = new dynObject('first');
layer1.setProperties(50,50,800,515, 'visible', 'images/usamap3.gif', 4)
//LAYER2
layer2 = new dynObject('second', 'first');
layer2.setProperties(815,160,30,30, 'visible', 'images/flag.gif');
layer2.slideTo(flgCoords.xcoor,flgCoords.ycoor,500,1)
document.attachEvent('onmousemove', 'showCoords()');
layer2.enableDragDrop();
layer2.limitMovement(0,0,825,515);
function init() {
function colorMe(color) {
activeObj.setBackground(color)
function showCoords() {
window.status = layer2.x +' '+ layer2.y
</script>
</head>
<body>
<input type="button" value="Sla op" onClick="flgCoords.store()">
<input type="button" value="Haal weg" onClick="flgCoords.remove()">
</body>
</html>
Voorbeeld staat op de volgende URL:
http://www.xs4all.nl/~rickr/map/map.html
Op het moment van plaatsen en daarna klikken 'Sla op' dan zouden de nieuwe coordinaten ingevoegd moeten worden in de cookie... echter dit gebeurt niet!
Ik mis een aantal triviale functies of 'if' statements...
Ik kom er echter niet uit...
Iemand??
  • Tim Schuhmacher
  • Laatst online: 09-09 15:04
Tim Schuhmacher
abasios
even je code tussen [ code ] en [ / code ] (zonder spaties) zetten.
Ksn het ook zijn dat ze wel goed opgeslagen worden en niet goed uitgelezen worden bij het tonen van de site?
Nee... ze worden nu opgeslagen als helemaal null (dacht ik)... Dat leest ie dan terug en zet 0,0 als x en y waarde.
Ik moet nog een mogelijkheid maken dat zodra het vlaggetje is verplaatst en je drukt op 'sla op' dat ie het wegschrijft... cookie blijft nu bij zowel x- als ycoor 'null' aangeven.
Dit staat in de cookie:
xcoor_ycoor|xcoor:&ycoor:|www.xs4all.nl/~rickr/map/
iemand?
  • crisp
  • Laatst online: 00:28
crisp
Devver
Pixelated
Dubbelpost: [topic=479625/1/25]
Ik heb even naar je code gekeken, maar vind het behoorlijk "verwarrend" om het maar netjes uit te drukken.
Ik meen dat je een standaard lib gebruikt om een aantal dingen op je site te regelen. Nu ben ik al niet zo'n voorstander van het gebruik van dat soort libs (zeker niet als je al niet zo'n JS held bent), en nu probeer je daaromheen nog wat dingen toe te voegen dmv cookies.
De code die je gebruikt om je cookies te zetten en uit te lezen komt ook nogal vaag over (en sorry, maar ik heb geen zin/tijd om me erin te verdiepen).
Een goede uitleg over cookies met JS kan je hier vinden; hopelijk heb je er wat aan.
Intentionally left blank
  • RM-rf
  • Laatst online: 20:02
RM-rf
1 2 3 4 5 7 6 8 9
het cookie wordt prima weggeschreven, maar probleem is dat zowel flgCoords.xcoor alswel flgCoords.ycoor beide een lege string zijn ("")
de fout zit hem in dat bij ondrag de waardes van layer2.x en layer2.y niet worden weggeschreven naar flgCoords.xcoor en flgCoords.ycoor
iets als
   flgCoords.xcoor = layer2.x
   flgCoords.ycoor = layer2.y
doet het mogelijk wel
edit: heb dat getest en dat werkt, althans het wordt prima gesaved, echter je tweede fout is dat je de waarde "" voor beide variabelen hard in je code zet en geen opdracht geeft ze uit de cookie te laden, bij een refresh staan de waardes dus weer terug op ""
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
  • cutter
  • Laatst online: 28-09-2025
cutter
Wannabe i7 fanboy
Op zaterdag 27 april 2002 17:32 schreef Djinkies het volgende:
iemand?
Als jij niet meer dubbelpost en niet binnen een uur je topic een schop geeft, gaat deze niet dicht: ok :) :)
het gaat inderdaad fout bij:
waarde is gewoon altijd 0.
Er zou bij:
//LAYER2
een soort 'als gevuld' moeten komen. Heb je daar een oplossing voor??
