ik had op me mdk bak gnu mp 3.1.1 staan maar bahamut moest een nieuwere versie dus heb ik 4.0.1 erop gezet maar nu zegt hij dat er geen 2 versies mogen zijn hoe verwijder ik de oude 3.1.1 ???
checking for gmp library matching with header... problem!
- gmp header version: 4.0.1
- gmp library version: 3.1.1
Your gmp library either has no version symbols, is not the correct 'gmp',
or the major versions of your gmp library and gmp header differ.
You cannot have two versions of the gmp library in your dynamic (.so)
library search path, this may be your problem.
You should upgrade gmp from the URL below.
If you do not want to upgrade gmp system wide:
You may make a directory "gmp" in the current directory
and place libgmp.a and gmp.h in that directory, and I will
autodetect it next time you run configure.
You can download gmp at http://www.swox.com/gmp, or any of the
GNU distribution sites (http://www.gnu.org for more information)
configure: error: bad library/header match
En toevallig vind ik dus van niet! :-)
