Quake2 config GeForce2 GTS????
(eerste post was in 't engels ergens ander, sorry :) )
always had played with Voodoo2, but now i got the new GeForce and i need to tweak the config for Quake2 again
putting the video-option on OpenGl didn't work this time.... it crashed back into software-mode :(
Default-OpenGl is beter then Software-mode but the game is very shocky..like missing 2 or 3 frames a second... not lag or so.
This is my current (voodoo2) config, can some1 please help me? thx :)
set s_mixahead "0.14"
set cl_predict "1"
set cl_maxfps "70"
set cl_particles "1"
set cl_run "1"
set gun_x "-4"
set gun_y "0"
set gun_z "4"
set gl_dynamic "3"
set gl_polyblend "0"
set gl_playermip "2"
set gl_flashblend "0"
set gl_ext_swapinterval "1"
set gl_swapinterval "1"
set gl_triplebuffer "1"
set gl_ztrick "1"
set gl_modulate "3"
set gl_shadows "0"
set cd_nocd "1"
set in_mouse "1"
set in_joystick "0"
set m_filter "1"
set freelook "1"
set rate 25000
set sensitivity "12"
set vof "120"
cl_maxfps moet iig op 140 ofsow .. bij 70 dropt ie maar 70 frames per seconde en dat is te weinig.... ook nog ffkes DirectX 8.0 proberen ofsow..
  • FatalError
  • Laatst online: 23:25
Als je CTF speelt moet je maxfps op 44 zetten d8 ik, want dan kan je in een bepaald level ergens tussendoor grappelen, wat anders niet mogelijk is.
If it ain't broken, tweak it! | gasloos sinds oktober 2025, hoekwoning 1978 | 10kWp PV, Panasonic K serie 7kW, Atlantic Explorer V5 270L | Tesla Model Y | 3x Victron MP2 6k5, 48kWh
heel goed, die maxfps is 't probleem echt ook niet denk ik, want in ctf1 moet ik wel door 't raampje kunne grappelen :)
