PSN jschut_82 | Xbox: JSchut82
| string[Length(string)] |
dus
| if str[lenght(str)] = '\\' then begin end; |
https://fgheysels.github.io/
Zie help:
function IsPathDelimiter(const S: string; Index: Integer): Boolean;
Description
Call IsPathDelimiter to determine whether a position in the string S contains the backslash path delimiter (?\?). The Index parameter specifies the position of the character in question, where 0 is the first byte, 1 is the second byte, and so on.
When working with a multi-byte character system (MBCS), IsPathDelimiter distinguishes between a true backslash character, and the byte of the same value that can appear as the second byte of a double byte character.
To test for more characters than just the backslash character, use IsDelimiter.
Description
Op donderdag 25 april 2002 12:21 schreef Kool het volgende:
IncludeTrailingBackslash
UIt de delphi help
function IncludeTrailingBackslash(const S: string): string;
Description
IncludeTrailingBackslash ensures that a path name ends with a trailing path delimiter ('\'). This function is included for backward-compatibility only. New programs should use IncludeTrailingPathDelimiter.
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
| ExtractFileDir(filename); |
haalt bij een directory de laatste "/" er voor je uit.
typo
typo
| ExtractFilePath(s); |
Zet er een \ achter
If then else matters! - I5 12600KF, Asus Tuf GT501, Gigabyte Gaming OC 16G 5080 RTX, Asus Tuf Gaming H670 Pro, 48GB, Corsair RM850X PSU, SN850 1TB, Arctic Liquid Freezer 280, ASUS RT-AX1800U router
