opengl problem
  • 51 views sinds 30-01-2008
ik had een demo op een p3 677 staan met windows xp (toen deed ie het nog)
gooi ik alles leeg > maak nieuwe partities aan >zet de zelvde xp er weer op doet ie het niet meer
kk alle nieuwe drivers eropgezet > noppes
iemand ideeen ?
dit zegt ie
1703 files in pk3 files
execing sof2mp_default.cfg
couldn't exec sof2mp.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
OS: Microsoft WinXP (NT)
CPU Detected: Pentium III (model 8)
---------- Input Initialization ----------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
WARNING: tess.xyz not 16 byte aligned
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
R_Terrain: Shutting down RENDERER terrain.....
GLW_StartOpenGL() - could not load OpenGL subsystem
------------- Input Shutdown -------------
iemand ? ;(
nVidia kaart? Nieuwe Detonators installeren.
  • DeMoN
  • Laatst online: 17-09 15:09
DeMoN
Pastafari
Hoort dit in WOS?
Welke videokaart heb je?
Welk spel gaat het om? Soldier of Fortune?
Zonder info kunnen wij niks.
Gamertag: Cosmicv0id
"Het woord Gods is voor mij niets meer dan een expressie en het product van menselijke zwakheid. De Bijbel is een verzamelwerk van legendes die achtenswaardig zijn maar ook primitief en kinderachtig.'' - Albert Einstein
Heb je dit al geprobeerd?
Drivers van je videokaart weggooien en daarna nieuwe installeren (nieuwste versie v/h internet afhalen, of je originele van je videokaart proberen, dus niet de standaard xp driver)Zo ja wat was het resultaat? zo nee probeer eens.)
  • Marv
  • Laatst online: 11-06 06:52
Rename (of delete) de config file eens (bij quake 3 is dat in baseq3\config.cfg o.i.d.)
Ik had dit met Quake 3.. en dat heb ik zo opgelost.
"Everything I've ever done or said is the complete opposite of what I've wanted" -- George
  • DeMoN
DeMoN
Pastafari
Mjah,.. stel dat je een VooDoo kaartje hebt, dan staat er op je CD een bestandje dat GLSETUP.exe heet.
Run die en dan werkt het waarschijnlijk wel 8-)
het gaat om een tnt2pro
  • Han
Han
Installeer gewoon de nieuwste detonater drivers...
Succes :)
Detonator drivers
