RTCW en firewallsettings
  • 76 views sinds 30-01-2008
  • harry64
  • Laatst online: 24-10 22:14
Simpele vraag :
Moet ik voor RTCW nog bepaalde poorten openzetten?
Ik krijg namelijk al de hele dag geen verbinding met de master server :( (sinds vandaag geinstalleerd)
Ik heb hier met bijv. UT en CS geen last van dus.......
  • Tachyon
  • Laatst online: 27-10 12:56
Tachyon
pop the glock
Uit de README-file:
2. Issues When Using Firewall Software:
If you are using firewall software such as Zone Alarm and you are experiencing
problems, make sure your firewall software is set to allow UDP packets through
on ports 27950 and 27960. These are the ports that Return to Castle Wolfenstein
uses for connection, message of the day, server browsing, and so forth.
In general we do not advise setting up a Return to Castle Wolfenstein server on
a machine that is also either a NAT server (such as Microsoft's Internet
Connection Sharing) or set up with ipForwarding for a Local Area Net (LAN) onto
the Internet. These machines see clients on your LAN as different addresses
from the Internet and thus you cannot authorize these clients.
If we do not change our direction, we will likely end up where we are heading.
  • IceStorm
IceStorm
This place is GoT-like!!!
Nou die was best te vinden toch ;)?
