VNCserver > client
Ik heb op mijn Linxu PC een VNCserver draaien.
Als ik met mijn windows client er heen gaan kan die niet conecten zegt die.
ik heb het ook al webbased gedaan.
pingen en telnet kan wel
Firewall :?
  • Dennahz
  • Laatst online: 16-08 19:23
Dennahz
Life feels like hell should.
zit op andere poort he.. 5800
dus ip:5800 intikken ;)
Twitter
The page cannot be displayed
The page you are looking for might have been removed or had its name changed.
op port 5800,5801,5802,5900,5901,5902
en ook via het vncproggie
Telnet werkt, ping werkt apache werkt port 80
Dit staat in de FAQ en dit heb ik allemaal gedaan en werkt goed.
Maar hij wil nog neit werken :9
My viewer failed to connect to my server!
VNC relies on a correctly-configured and operational TCP/IP network, so please make 100% sure that your TCP/IP setup is right before you start asking questions on the mailing list. Here are some things you should check before assuming it's a VNC problem; consult your local expert if you don't know how to check them:
Can you ping the server machine from the client?
Is the VNC server definitely running on the server machine?
The server listens on port 5900+displaynumber. Can you telnet to this port from the client machine?
Have you specified the address correctly to the viewer? If you're using a display number other than zero for the server, (usually the case on Unix machines), did you remember to specify it?
Is the server name known to the DNS? Try using an explicit IP address instead of a name (eg. 123.456.78.9:0 instead of snoopy:0).
Do you have any firewalls or proxies in the way that could be blocking acess?
If using the java client, did you remember to specify the correct port as part of the URL? (eg. http://snoopy:5800)?
Can you try running either the server, or the client, or both, on different machines on your network to find whether the problem is at one end or the other?
Can you try running the software on a different architecture? eg., if you are having problems viewing a PC from another PC, can you try connecting from a Unix machine?
  • Dennahz
Dennahz
zijn die poort uberhaupt wel beschikbaar :?
mayb een vuurmuur ofzow?
Twitter
Op zaterdag 20 april 2002 15:23 schreef BrEeZeR het volgende:
nee heb geen firewall ingestelt
maar als ik dus vncserverstart dan geeft vncserver stared
localhost:3
lijkt mij dus ip en dan port 3
heb ook al gedaan maar werkt niet
staat me bij dat je bij die client van vnc ook het monitor nummer moet opgeven... meestal is dit 0 maar dat kan je instellen... lijkt mij dat die localhost:3 betekend dat het monitor nummer 3 is... (beetje vaag maar toch) kweet niet of je dit al had gebprobeerd, maar denk laat ik t toch maar ff zeggen ;)
ohnee, dat zeg je net... |:(
  • blaataaps
Op zaterdag 20 april 2002 15:25 schreef itstim het volgende:
localhost:3
Dat lijkt erop dat ie op localhost bind, en niet op een extern ip. Zolang ie op localhost zit, kan hij nooit van buitenaf bereikt worden. Hoe je dat verder met vnc moet veranderen, weet ik niet, misschien es zoeken op localhost in de config.
  • Joto
  • Laatst online: 11-08 21:55
kijk eens of de poorten berijk baar zijn van buitenaf, een poortscannertje is een handig tooltje
1+1+1 = 1
http://www.linux-mag.com/2000-11/desktop_02.html
ik lees dit net. en ik vergeet dus wat.
Maar hoe kan ik dit doen :|
# mkdir -p /usr/
local/vnc/classes
# cp classes/* /usr/
local/vnc/classes
ik verw8 dat dit in de root moet. maar in de root heb bijna niks.
als ik dir doe in de xconsole krijg ik alleen dit:
Desktop Serverlkog StartLog Bin
das niet goed toch?/
ik kan in MS netjes toch alles ziet dus dat probleem is er niet meer. maar als ik de logfile bekijk zegt die dit:
VNC @ Port 5905
HTTP @ port 5805
http://linuxserver:5805
als ik deze porten doe krijg ik dit in IE:
Please try the following:
Open the s: home page, and then look for links to the information you want.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
If you still cannot open the page, click the Internet Explorer
Search button to look for similar sites.
Internet Explorer
het werkt bijna ik kom binnnen via de webpage op de server.
allees kan ik geen startx doen?!1!
