if else etc code doesnt work help pls
  • 26 views sinds 30-01-2008
<?php
$db = @mysql_connect("localhost", "******", "*******");
mysql_select_db("*********", $db);
$ip=getenv(REMOTE_ADDR);
$result = mysql_query("SELECT * FROM rates where REMOTE_ADDR='$ip' AND rid=$id;",$db);
$number = mysql_numrows($result);
<? printf("%s\n", $number);?>
if ($number != 0) {
<p>Here you rate the users for skill, loox and attitude</p>
<p>Submit only once, go BACK and RELOAD to see your addition.</p>
<form method="post" action="<?php ratesadds.php3+$id?>">
<div align="left">
<p>Skill Rating:
<select name=ratings>
<option value="">- Select -</option>
<option value="20">blaa<option>
<option value="40">Novice</option>
<option value="60">Average</option>
<option value="80">Inhuman</option>
<option value="100">Godlike</option>
</select>
</p>
<br>
<?php $rid = $id; ?><input type="hidden" name="rid" value="<?php echo $rid ?>"
<br>
</p>
<p>
<input type="Submit" name="submit" value="Enter information">
</p>
</div>
</form>
} else if ($submit) {
<?PHP
// process form
$db = @mysql_connect("localhost", "***", "**********");
mysql_select_db("*******",$db);
$date = date("Y-m-d");
$sql1 = "INSERT INTO rates (ratings,rid,REMOTE_ADDR,date) VALUES ('$ratings','$rid','$REMOTE_ADDR','$date')";
$result1 = mysql_query($sql1);
} else {
<?PHP
echo "YOUR HAVE VOTED.\n";
Kan iemand me helpen met deze code. Ik denk dat het de plaatsingen van de code van de if else zijn. BvD
  • Janoz
  • Laatst online: 09-09 20:58
Janoz
Moderator Devschuur®
!litemod
We gaan hier niet ff source neerplanten en door iemand anders laten debuggen!!! Zie ook quickstart
tip: Php die je wilt laten uitvoeren hoort tussen php tags te staan.
