Voor iedereen die het nog niet wist:de oplossing is afkomstig van het creative forum
Het kan dus blijkbaar wel. Maar het is even zoeken schijnbaar. Het werkt natuurlijk alleen als bij de test wel geluid uit de centrale speaker komt.
opmerking Craig:
"I've got the same problem, the set is working perfectly, when I try the test from creative, my centre speaker is making some noise, but when I'm playing music, the center speaker doesn't react..."
reactie lotgenoot:
"i had the same problem with my 5300 series, my centre channel had no sound, to correct this, open play centre from start menu > creative > play centre, to the left of the eax button there is a small arrow to expand the playcenter, on the the newly expanded section (bottom) you'll see the letters cmss, click cmss them click on."
resultaat bij Craig:
"woohoo i finally found it, for all of you who dont know you need to go into player mode rather than jukebox to get the arrow and cmss.
Veel plezier.
lock
opmerking Craig:
reactie lotgenoot:
Veel plezier.
lock
