ik krijg de volgende error
ik krijg deze melding ook kmet apt-get upgrade/install/distupgrade
is hier ong wat aan te doen ?
| Area51:/var/spool/mail# apt-get remove koffice Reading Package Lists... Done Building Dependency Tree... Done The following extra packages will be installed: mysql-client mysql-server The following packages will be REMOVED: kde koffice 2 packages upgraded, 0 newly installed, 2 to remove and 81 not upgraded. 1 packages not fully installed or removed. Need to get 0B/2922kB of archives. After unpacking 98.3kB will be freed. Do you want to continue? [Y/n] y Preconfiguring packages ... dpkg: syntax error: invalid mode in statusoverride file E: Sub-process /usr/bin/dpkg returned an error code (2) Area51:/var/spool/mail# |
specs : http://specs.tweak.to/7435
