Pioneer NS-DV77 regiovrij?
  • 142 views sinds 30-01-2008
  • sjempie
Binnenkort ben ik al het goed is de gelukkige bezitter van een Pioneer NS-DV77 - home cinema set.
Ik ben benieuwd of iemand mij kan vertellen of deze dvdspeler regiovrij is of evt regiovrij te krijgen is?
  • JvS
  • Laatst online: 12:58
JvS
Ik heb hem zelf ook
www.elvic.nl kan dat.
  • sjempie
dank voor de info, ik zal ff kijken, andere mensen nog andere ideeen?
Ik vond dit ergens op het internet. Weet niet of het werkt, heb 't zelf nog niet geprobeerd. NS-DV88 schijnt overigens (technisch) identiek te zijn aan NS-DV77...
The Ultimate DVD Upgrade NS-DV88 User Manual
Introduction
The NS-DV88 DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
n Multiregion capability
n Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
n Pioneer NS-DV77
n Pioneer NS-DV88
Operating Instructions
The features of the DVD Upgrade are all controlled by the remote control handset of the DVD player through the menu. Follow the instructions as detailed bellow:
1. Turn the player ON without a disc in it or disk tray out
2. On the remote control, press 'DVD' (blue colour)
3. Press 'SET UP'
4. Use right arrow to select 'General'
5. Use down arrow to select 'Basic'
6. Press 'ENTER' on the remote control
7. Press 'DVD DISP'
You should see the region code and OSD version that the player is set to
8. Hold down 'SHIFT' and press 'CONDITION' (green colour)
9. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
10. Press 'DVD DISP' on the remote to control the region
11. Press ' SETUP ' on the remote to exit. Play the disc
