Ik zie wel is programmatjes waar je zo door het windowtje half heen kan kijken zodat je vaag de achtergrond van windows ziet. Hoe krijg ik deze (geloof alpha color)?
Transparant zou ook wel kunnen.Ik bedoel niet dat het helemaal transparant moet worden hoor. ik wil door bijvoorbeeld witte licht de achtergrond zien.
Als je had geweten dat dat in Windows opacity heet had je 'm in 5 seconden met google gevonden...
In .net is dat dacht ik trouwens gewoon een property
quote van Karl E. Peterson's One-Stop Source Shop
Werkt trouwens erg leuk
Translucent.zipShows how to create "layered" windows in Windows 2000. This demo provides a drop-in ready class that can be used to either do an Alpha-blend for translucency ranging from totally opaque to completely transparent, or the class can be used to select a single color to be rendered transparent. In either mode, the entire form and all its child controls are affected. Additional demos show how to create an irregularly shaped form using the Color Key approach to layered windows, and how to set the opacity of any window in the system. Now includes updated demos of WinRgn and WndPick, built to show off use of layered windows.
Exact expert nodig?
Tada
Je moet er wel ff alle overbodige enters uitslopen.
29
30
31
32
33
34
35
36
37
38
39
40
| 'Semi Transparent windows (2000/XP/Me?) Declare Function SetLayeredWindowAttributes Lib "user32.dll" (ByVal hwnd As Long, ByVal crKey As Long, ByVal bAlpha As Byte, ByVal dwFlags As Long) As Long Declare Function UpdateLayeredWindow Lib "user32.dll" (ByVal hwnd As Long, ByVal hdcDst As Long, pptDst As Any, psize As Any, ByVal hdcSrc As Long, pptSrc As Any, crKey As Long, ByVal pblend As Long, ByVal dwFlags As Long) As Long Public Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long Public Const GWL_EXSTYLE = (-20) Public Const WS_EX_LAYERED = &H80000 Public Const ULW_COLORKEY = &H1 Public Const ULW_ALPHA = &H2 Public Const ULW_OPAQUE = &H4 Public Const AC_SRC_OVER = &H0 Public Const AC_SRC_ALPHA = &H1 Public Const AC_SRC_NO_PREMULT_ALPHA = &H1 Public Const AC_SRC_NO_ALPHA = &H2 Public Const AC_DST_NO_PREMULT_ALPHA = &H10 Public Const AC_DST_NO_ALPHA = &H20 Public Const LWA_COLORKEY = &H1 Public Const LWA_ALPHA = &H2 Public Sub MakeTransparent(hwnd As Long, Rate As Byte) On Error Resume Next '### funktioniert nur unter Win2000 - XP!!! '### macht das Fenster, dessen hWnd über ' geben wurde, transparent '### Rate: 254 = normal 0 = ganz transpa ' rent '### 190 ist z.B. ein guter Wert Dim WinInfo As Long WinInfo = GetWindowLong(hwnd, GWL_EXSTYLE) WinInfo = WinInfo Or WS_EX_LAYERED SetWindowLong hwnd, GWL_EXSTYLE, WinInfo SetLayeredWindowAttributes hwnd, 0, Rate, LWA_ALPHA End Sub |
