Carmageddon TDR 2000 Cheats
  • 155 views sinds 30-01-2008
  • Gman
  • Laatst online: 14-03 20:42
Ik wordt gek van die tijd!
Kan niet eens relaxed rondtuffen.
Iemand cheats ervoor?
  • Gman
Grrrrrrr zodra het topic gepost is vindt ik ze.
http://www.pcgameworld.com/cheats/c/carmageddontdr2000/index.htm
Hit ` and type any of the following cheat codes:
Code Result
hereComesTrouble Enable Cheat Codes
openLevelsGuv All Levels
cash Increase Money (+$10,000)
invincible God Mode
ai on/off AI On/Off
setCar [CARNAME] Change Your Car to [CARNAME]
makeai [CARNAME] Create Opponent [CARNAME]
WasteAll Destroy All Cars
lastlap Start on Final Lap
lastcheckpoint All Checkpoints Checked Except Last
adventure Text Adventure Mini-Game
damage_multiplier # Increase Damage to #
addPowerup # Add Powerup (#=Name)
breakCar # Damage Car (#=Name)
peds on/off Pedestrians On/Off
enablebuy Allows You to Buy All Cars
PowerUp Cheat
To find the names of powerups for the addPowerup cheats, look in your Assets folder and load a file called PowerupStrings_Internal.txt.
Credit Cheat
Make a backup of the Carma.pak file in the assets folder. Then open the file in wordpad. scroll down to the part that starts:
ENDDIFFICULTY
Here you will find the attributes for Ped_Credits / Checkpoint_credits and the like ...add a few zeros to the numbers and remove the line
APO_TRADE_OFFENSIVE
that is at the bottom of this part of the text or else the hack won't work. This hack will make it nice and easy to score credits and afford all the cars.
No Timer
To remove the time limit in the game, edit the options.txt file in the Assets folder. Search for the string USE_TIMER, and change the value from 1 to 0.
Commands for Text Adventure
go (direction) - Causes you to move there.
kill (Zombie's name) - Causes you to attack the Zombie.
look (Name of person or object) - Gives a detail description of who or what it is.
look - Tells you who is in the area and which directions you can go.
look again - Instant replay.
inventory - Shows you what you are carrying.
get (item name) - Allows you to get that item.
quit - Exits text adventure.
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 21:31
Heb je de demo??
Als je niet de DEMO hebt kun je gewoon de timer uitzetten, kun je doen wat je wilt..
Jah.. en je kunt gewoon arcade kiezen en dan tijd op 30 minuten zetten en aantal rondes op 999...
  • Gman
Nouw ik heb toch echt wel de volledige versie...tenminste als 400 mb volledig is :).
Maar het werkt niet!
die timer dan...
hey waar hebbie em vandaan?
kun je misschien ff een link maile of icqen?
ben er ook al een hele tijd naar op zoek ;)
