Opheldering rond ti4200
  • McFlipp
  • Laatst online: 22-04-2023
Hmmzz cool, dit lees ik net op Tech Report:
TR: Does NVIDIA sell the RAM and GPU chips to board makers together for the Ti 4200? If so, will most cards come with the 4ns Hynix RAM on the reference card?
Steve: We do not currently plan to bundle memories for the 4200. We have a number of memory vendors lined up for qualification on the 64MB board.
Hmzzz das toch best wel cool, hopelijk komen ze ook met 3,6 of zelfs 3,3ns chippies >:)
En verder stond er nog dit:
TR: What's really different about the 4200 reference design other than size?
Steve: Lots of stuff is different on the 4200. These changes are required to meet the requirements of that market segment. Memory is different (TSOP versus BGA). Power supply is different. 6 layer board versus 8 layer board.
TR: Will the Ti 4200 128MB cards come on the same PCB design, or do you all expect the 128MB cards to use the Ti 4600/4400 reference design?
Steve: We expect the 128MB 4200 to come on the same design you see for 64MB. The board can take 4x16 or 8x16 memories. I would say that a 4200 on the same PCB as the 4400 or 4600 is possible (those two PCBs are different as well), although unlikely at this time.
TR: Also, would you expect to see newer Ti 4400 and 4600 cards coming based on the Ti 4200 64MB reference PCB design? Seems like the more compact cards are better, all other things being equal.
Steve: No. Running as fast as the 4400 and 4600 do takes a different design. Different power as well as different memories (BGA's). These require different routing and layout.
TR: One other thing: do you expect most Ti 4200 cards to come with the DVI-out port and dual display support? Or is that one totally out of your hands?
Steve: This is based on what our partners decide to do. The board is capable of VGA/DVI-I if the AIC desires.
Wordt dus wel een leuk kaartje die ti4200. Maar wat is TSOP??? Wat is eigenlijk het verschil met BGA??
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
  • McFlipp
^^Schop^^ :)
  • mvds
  • Laatst online: 19-09 20:39
mvds
Totally awesome!
Op woensdag 10 april 2002 12:22 schreef McFlipp het volgende:
^^Schop^^ :)
Auw!
  • McFlipp
Op woensdag 10 april 2002 12:27 schreef obsidian het volgende:
Auw!
Maaruh is er iemand die een antwoord weer op mijn vraag?
Of weet niemand het? >:)
  • PASware
  • Laatst online: 21:05
sory geen antwoord, maar die ti4200 is toch wel de beste koop van alle Geforce 4 kaartjes
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
  • McFlipp
Op woensdag 10 april 2002 12:34 schreef PASware het volgende:
Idd, zeker als je er zelf nog wat mooie heatsinkjes opzet, en als je 3,6ns geheugen hebt ofzo >:) (1000/3,6=277, 277x2=555mhz minimaal >:) )
Neem je gainward, de yield daarvan is meestal beter, krijg je hem misschien wel naar 580 :P. Op de core een Crorb :> en die krijg je dan naar 300+... 300/580, mjammie :9~
