Damn, da's sterk! Alsof ik het aan mijn water voelde
Maar goed, die nieuwe is vlgs mij exact hetzelfde als de 901HT, maar dan met dit voetje
erbij in gebouwd.A901HT
CRT 19" Diamondtron NF(TM) True Flat CRT
Aperture Grill Pitch :0.25mm
Anti-static, Anti-reflection coating
P22 Med-Short phosphor
Viewable Area: 18"
Sync Frecuency fH:30-115KHz fV:50-160Hz
Max Resolution 1920x1440
Plug and Play VESA DDC 2B(TM)
Input connector D-SUB mini 15pin, BNC
Input Power AC90-132V 50/60Hz
Power consumption MAX 140w (Normal),10w(Stand by),5w(Off mode)
Dimension W17.7" x H17.6" x D17.6"
Weight 62 Lbs (inc. Stand)
Approval TCO' 99,FCC-B,UL/C-UL
en de nieuwe monitor:
A902MT (Available from November 2000)
CRT 19" Diamondtron NF(TM) TrueFlat CRT
Aperture Grill Pitch :0.25mm(center),0.27mm(corner)
Viewable Area: 18"
Max Resolution 1920 x 1440 / 1280 x 1024 (Recommended)
Audio input 0.7Vrms(Max)
Headphone connector 3.5mm mini Jack(stereo)
Speakers 1W x 2 with amplifier
USB connector REV.1.1 compatible(self-powered hub)
Upstream:seriesB Downstream:series A
1Upstream(PCside) 4Downstream(Peripheral side)
Input connector 2 x D-SUB mini 15pin
Power consumption MAX 138w (Normal),10w(Stand by),3w(Off mode)
Dimension W17.7" x H17.7" x D17.6"
Weight 52.8 Lbs (inc. Stand)
Ach weet u wat meneer, doet u ze alletwee maar, hoeft niet ingepakt te worden, het is om zo mee te nemen.
