Everyone complains of his memory, no one of his judgement.
Anoniem: 9329
hier zit ie in verwerkt dus misschien dat je hem eruit kunt halen...
#!/bin/perl5.005_03
# Guestbook Version 2.3.1 #
# Copyright 1996 Matt Wright mattw@worldwidemart.com #
# Created 4/21/95 Last Modified 10/29/95 #
# Scripts Archive at: http://www.worldwidemart.com/scripts/ #
# COPYRIGHT NOTICE #
# Copyright 1996 Matthew M. Wright All Rights Reserved. #
# Guestbook may be used and modified free of charge by anyone so long as #
# this copyright notice and the comments above remain intact. By using this #
# code you agree to indemnify Matthew M. Wright from any liability that #
# might arise from it's use. #
# Selling the code for this program without prior written consent is #
# expressly forbidden. In other words, please ask first before you try and #
# make money off of my program. #
# Obtain permission before redistributing this software over the Internet or #
# in any other medium. In all cases copyright and header must remain intact.#
# Set Variables
$guestbookurl = "http://www.dreamdesign.nl/guestbook.html";
$guestbookreal = "/www/cust/y/7/0/0/70002/docs/guestbook.html";
$guestlog = "/www/cust/y/7/0/0/70002/docs/guestlog.html";
$cgiurl = "/www/cust/y/7/0/0/70002/cgi-bin/guestbook.pl";
$date_command = "usr/bin/date";
# Set Your Options:
$mail = 0; # 1 = Yes; 0 = No
$uselog = 1; # 1 = Yes; 0 = No
$linkmail = 1; # 1 = Yes; 0 = No
$separator = 1; # 1 = <hr>; 0 = <p>
$redirection = 0; # 1 = Yes; 0 = No
$entry_order = 1; # 1 = Newest entries added first;
# 0 = Newest Entries added last.
$remote_mail = 0; # 1 = Yes; 0 = No
$allow_html = 1; # 1 = Yes; 0 = No
$line_breaks = 1; # 1 = Yes; 0 = No
# If you answered 1 to $mail or $remote_mail you will need to fill out
# these variables below:
$mailprog = '/usr/lib/sendmail';
$recipient = 'you@your.com';
# Done
# Get the Date for Entry
$date = `$date_command +"%A, %B %d, %Y at %T (%Z)"`; chop($date);
$shortdate = `$date_command +"%D %T %Z"`; chop($shortdate);
# Get the input
read(STDIN, $buffer, $ENV{'CONTENT_LENGTH'});
# Split the name-value pairs
@pairs = split(/&/, $buffer);
foreach $pair (@pairs) {
($name, $value) = split(/=/, $pair);
# Un-Webify plus signs and %-encoding
$value =~ tr/+/ /;
$value =~ s/%([a-fA-F0-9][a-fA-F0-9])/pack("C", hex($1))/eg;
$value =~ s/<!--(.|\n)*-->//g;
if ($allow_html != 1) {
$value =~ s/<([^>]|\n)*>//g;
$FORM{$name} = $value;
# Print the Blank Response Subroutines
&no_comments unless $FORM{'comments'};
&no_name unless $FORM{'realname'};
# Begin the Editing of the Guestbook File
open (FILE,"$guestbookreal") || die "Can't Open $guestbookreal: $!\n";
@LINES=<FILE>;
close(FILE);
$SIZE=@LINES;
# Open Link File to Output
open (GUEST,">$guestbookreal") || die "Can't Open $guestbookreal: $!\n";
for ($i=0;$i<=$SIZE;$i++) {
$_=$LINES[$i];
if (/<!--begin-->/) {
if ($entry_order eq '1') {
print GUEST "<!--begin-->\n";
if ($line_breaks == 1) {
$FORM{'comments'} =~ s/\cM\n/<br>\n/g;
print GUEST "<small>($FORM{'comments'})</small><br>\n";
if ($FORM{'url'}) {
print GUEST "<br><b><font face\=arial size\=2 color\=black>$FORM{'realname'}</font></b><br>";
else {
print GUEST "<b>$FORM{'realname'}</b>";
if ( $FORM{'username'} ){
if ($linkmail eq '1') {
print GUEST " \<<a href=\"mailto:$FORM{'username'}\">";
print GUEST "$FORM{'username'}</a>\>";
else {
print GUEST " <$FORM{'username'>:)";
print GUEST "<br>\n";
if ( $FORM{'city'} ){
print GUEST "$FORM{'city'},";
if ( $FORM{'state'} ){
print GUEST " $FORM{'state'}";
if ( $FORM{'country'} ){
print GUEST "<font size\=2 color\=black face\=arial> $FORM{'country'}</font><br><br>";
if ($separator eq '1') {
print GUEST "$date<br><br>\n\n";
else {
print GUEST " - $date<p>\n\n";
if ($entry_order eq '0') {
else {
print GUEST $_;
close (GUEST);
# Log The Entry
if ($uselog eq '1') {
&log('entry');
# Options
# Mail Option
if ($mail eq '1') {
open (MAIL, "|$mailprog $recipient") || die "Can't open $mailprog!\n";
print MAIL "Reply-to: $FORM{'username'} ($FORM{'realname'})\n";
print MAIL "From: $FORM{'username'} ($FORM{'realname'})\n";
print MAIL "Subject: Entry to Guestbook\n\n";
print MAIL "You have a new entry in your guestbook:\n\n";
print MAIL "------------------------------------------------------\n";
print MAIL "$FORM{'comments'}\n";
print MAIL "$FORM{'realname'}";
print MAIL " <$FORM{'username'>:)";
print MAIL "\n";
print MAIL "$FORM{'city'},";
print MAIL " $FORM{'state'}";
print MAIL " $FORM{'country'}";
print MAIL " - $date\n";
close (MAIL);
if ($remote_mail eq '1' && $FORM{'username'}) {
open (MAIL, "|$mailprog -t") || die "Can't open $mailprog!\n";
print MAIL "To: $FORM{'username'}\n";
print MAIL "From: $recipient\n";
print MAIL "Thank you for adding to my guestbook.\n\n";
print MAIL "\n";
close (MAIL);
# Print Out Initial Output Location Heading
if ($redirection eq '1') {
print "Location: $guestbookurl\n\n";
else {
&no_redirection;
# Subroutines
sub no_comments {
print "Content-type: text/html\n\n";
print "<html><head><title>No Comments</title></head>\n";
print "<body><h1>Your Comments appear to be blank</h1>\n";
print "The comment section in the guestbook fillout form appears\n";
print "to be blank and therefore the Guestbook Addition was not\n";
print "added. Please enter your comments below.<p>\n";
print "<form method=POST action=\"$cgiurl\">\n";
print "Your Name:<input type=text name=\"realname\" size=30 ";
print "value=\"$FORM{'realname'}\"><br>\n";
print "E-Mail: <input type=text name=\"username\"";
print "value=\"$FORM{'username'}\" size=40><br>\n";
print "City: <input type=text name=\"city\" value=\"$FORM{'city'}\" ";
print "size=15>, State: <input type=text name=\"state\" ";
print "value=\"$FORM{'state'}\" size=15> Country: <input type=text ";
print "name=\"country\" value=\"$FORM{'country'}\" size=15><p>\n";
print "Comments:<br>\n";
print "<textarea name=\"comments\" COLS=60 ROWS=4></textarea><p>\n";
print "<input type=submit> * <input type=reset></form><hr>\n";
print "Return to the <a href=\"$guestbookurl\">Guestbook</a>.";
print "\n</body></html>\n";
# Log The Error
&log('no_comments');
exit;
sub no_name {
print "<html><head><title>No Name</title></head>\n";
print "<body><h1>Your Name appears to be blank</h1>\n";
print "The Name Section in the guestbook fillout form appears to\n";
print "be blank and therefore your entry to the guestbook was not\n";
print "added. Please add your name in the blank below.<p>\n";
print "Your Name:<input type=text name=\"realname\" size=30><br>\n";
print " value=\"$FORM{'username'}\" size=40><br>\n";
print "value=\"$FORM{'state'}\" size=2> Country: <input type=text ";
print "value=USA name=\"country\" value=\"$FORM{'country'}\" ";
print "size=15><p>\n";
print "Comments have been retained.<p>\n";
print "<input type=hidden name=\"comments\" ";
print "value=\"$FORM{'comments'}\">\n";
print "<input type=submit> * <input type=reset><hr>\n";
# Log The Error
&log('no_name');
exit;
# Log the Entry or Error
sub log {
$log_type = $_[0];
open (LOG, ">>$guestlog");
if ($log_type eq 'entry') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate]<br>\n";
elsif ($log_type eq 'no_name') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate] - ERR: No Name<br>\n";
elsif ($log_type eq 'no_comments') {
print LOG "$ENV{'REMOTE_HOST'} - [$shortdate] - ERR: No ";
print LOG "Comments<br>\n";
# Redirection Option
sub no_redirection {
# Print Beginning of HTML
print "Content-Type: text/html\n\n";
print "<html><head><title>Thank You</title></head>\n";
print "<body><h1>Thank You For Signing The Guestbook</h1>\n";
# Print Response
print "Thank you for filling in the guestbook. Your entry has\n";
print "been added to the guestbook.<hr>\n";
print "Here is what you submitted:<p>\n";
print "<br><br><br></td></tr><tr><td><small>($FORM{'comments'})</small><br>\n";
if ($FORM{'url'}) {
print "$FORM{'realname'}</td></tr><tr><td><br><br><br>";
else {
print "$FORM{'realname'}";
print " <<a href=\"mailto:$FORM{'username'}\">";
print "$FORM{'username'}</a>>";
else {
print " <$FORM{'username'>:)";
print "<br>\n";
print "$FORM{'city'},";
print " $FORM{'state'}";
print " $FORM{'country'}";
print " - $date<p>\n";
# Print End of HTML
print "<hr>\n";
print "<a href=\"$guestbookurl\">Back to the Guestbook</a>\n"; print "- You may need to reload it when you get there to see your\n";
print "entry.\n";
print "</body></html>\n";
exit;
#!/bin/perl5.005_03
# Set Variables
# Set Your Options:
# Done
# Get the input
$value =~ tr/+/ /;
@LINES=<FILE>;
close(FILE);
$SIZE=@LINES;
$_=$LINES[$i];
if ($FORM{'url'}) {
else {
else {
else {
else {
print GUEST $_;
close (GUEST);
# Log The Entry
&log('entry');
# Options
# Mail Option
if ($mail eq '1') {
print MAIL "\n";
close (MAIL);
print MAIL "\n";
close (MAIL);
else {
&no_redirection;
# Subroutines
sub no_comments {
# Log The Error
exit;
sub no_name {
# Log The Error
&log('no_name');
exit;
sub log {
$log_type = $_[0];
# Print Response
if ($FORM{'url'}) {
else {
else {
print "<br>\n";
# Print End of HTML
print "<hr>\n";
print "entry.\n";
exit;
wie weet moet hij het in php hebben
If it ain't broken it doesn't have enough features
juist, ik dacht meer zo aan <?php?>, maar toch bedankt pim_ :):)
euh.. bedoel je nou echt htmlentities() ?? Da's wel een hele makkelijke
(en ook enigszins rtfm)
Als je de tekst tussen < en > echt helemaal weg wilt hebben, dan wordt het ietsjes ingewikkelder
Je zou dan kunnen zoeken naar de < en > met een of andere string functie, of je verzint er een mooie regexp voor die het in één regel voor elkaar krijgt...
Volgens mij zoek je toch echt htmlspecialchars()
Anoniem: 4255
<BLOCKQUOTE><font size=1 face=Verdana, Arial, Helvetica>quote:</font><HR>$reactie = strip_tags($reactie);[/quote]Waarom werkt dit bij mij niet...
Anoniem: 11648
Het werkt alleen in versies 3.0.8 - 3.0.16 en PHP4 >= 4.0b2
Anoniem: 4255
Op mijn (virtuele) server staat PHP 4.0.0 volgens phpinfo();.
Daar werkt het dus blijkbaar niet op
Lastig.
Zijn er nog meer manieren om met mijn versie van PHP toch de HTML weg te strippen?
Lastig.
Anoniem: 11648
Reguliere expressies. Je wilt dat alle < en > eruit worden gezeefd en worden omgezet naar < en >.
HTH
HTH
