127 MB !!! PART 2 !!
  • 34 views sinds 30-01-2008
jaja hierben ik weer, en weer met een probleem over mohaa!
ik heb mn ram ontvangen dat ik bestelt heb maar heb ondertussen wel een andere error gevonden! als ik mn mohaa in win xp pro nl speel dan craschd mn pcniet maar valt mn pc terug naar windows en de mohaa game launcher, deze geeft mij deze foutmelding:
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 12 2001
----- FS_Startup -----
Current search path:
C:\mijngamefolder\MOHAADemo\main\Pak5.pk3 (6 files)
C:\mijngamefolder\MOHAADemo\main\Pak4.pk3 (284 files)
C:\mijngamefolder\MOHAADemo\main\Pak3.pk3 (397 files)
C:\mijngamefolder\MOHAADemo\main\Pak2.pk3 (490 files)
C:\mijngamefolder\MOHAADemo\main\Pak1.pk3 (199 files)
C:\mijngamefolder\MOHAADemo\main\Pak0.pk3 (1546 files)
C:\mijngamefolder\MOHAADemo/main
2922 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec safemode.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 16
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'D:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
alsjeblieft geef me geen antwoord van: dan moet je die driver downen, want ik heb alle drivers al, en als je toch denktdat ik een driver nodig heb zet dat de directe link neer ! ik heb (nog steeds) een p3 800 mhz met tnt2 pro en windows 98 2e editie en.... 127 MB Ram haha maargoed plz help me out here !!
mohaa moet wel vreselijk kewl zijn... anders had ik dit nooit willen meemaken !! ':'( ;)
[topic=449687]
Deze is nog steeds open en mag best daar gepost worden ... ;)
