Klaar voor een nieuwe uitdaging.
Zit hij niet in de Archive?
Programmer - an organism that turns coffee into software.
you tell me...Op woensdag 03 april 2002 16:59 schreef LuCarD het volgende:
hmz, daar heb ik bar weinig aan: een waslijst van miniscule veranderingen tot aan de ; toeOp woensdag 03 april 2002 17:03 schreef LuCarD het volgende:
http://cvs.php.net/co.php/php4/ChangeLog?r=1.1003
tnx anyways... ik wacht maar af
Jij bent toch zo'n mac OS X figuur?
Geen idee wat het is maar goed :_update for Mac OS X. -traditional-cpp is no longer recommended.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
| - ATTENTION!! register_globals defaults to 'off' now !!!
- Fixed pg_last_notice() crash. (Yasuo)
- Modified the mysql extension to disable 'LOAD LOCAL' when safe mode is
enabled. (Jason)
- Added CLI (command line interface) sapi which is more suitable for writing
shell scripts. Some of the differences to CGI sapi are: no HTTP headers,
plain text error messages, does not change working directory, have a new -r
option which executes a piece of PHP code directly from the commmand line, etc.
"make install" will install CLI SAPI version of php in {PREFIX}/bin/php while
CGI is renamed and installed as {PREFIX}/bin/php-cgi. (Edin)
- Fixed HTTP file upload support to handle big files better. (Jani)
- Major modifications to the Sockets Extension and its API (Jason):
. Fixed numerous bugs.
. Added automatic host lookup capability to all functions that take addr's.
example: socket_connect($sock, 'www.yahoo.com', 80);
. Corrected and standardized host lookup errors
. Modified socket_recv() behavior. [$r=socket_recv($sock, $buf, $len, $flags)]
. Added socket_set_block() which changes a socket into blocking IO mode
. Modified socket_last_error() to not clear the last error
. Added socket_clear_error() which clears the last error on a socket
. Removed all code pertaining to fd_sets (socket_fd_*)
. Modified/Improved socket_select() to accept array of resources instead of
fd_sets. example:
<?php
$wfds=$rfds=array($sock1, $sock2, $sock3, $sock7);
$r=socket_select($rfds, $wfds, NULL, 1);
print "Ready to read:\n"; var_dump($rfds);
- Added optional 3rd parameter "int encoding_mode" to gzencode() and fixed
parameters to conform documentation. (Stefan)
- Changed read_exif_data() to be an alias of exif_read_data(). (Marcus)
- Added exif_tagname() function which returns the names of tags and
exif_thumbnail() function to extract embedded thumbnails. (Marcus)
- Fixed iconv support with FreeBSD. (kalowsky)
- Cleaned up the posix extension: (Markus)
. Removed unwanted warning messages
. Added posix_errno() and posix_strerror() for fetching error messages
. Changed the way posix_getgrnam() and posix_getgrgid() return their values
(breaks BC but makes more sense)
. Does not include functions in symbol table which aren't supported on host
system.
- Added TIFF support for getimagesize() and read_exif_data(). (Marcus)
- Changed the Velocis extension namespace to Birdstep to reflect new product
name. Added aliases for BC. (James)
- Added safe_mode checks for opendir(). (jflemer)
- Changed the 2nd parameter in pgsql_fetch_*() functions to support NULL if
all 3 parameters are supplied, but you do not want to provide a row number.
(Derick)
- Improved iconv() when using libc's iconv. (Yasuo)
- Added PHP_SAPI constant which contains the name of running SAPI. (Edin)
- Added ob_get_status() which returns an array of buffers with their status.
(Yasuo)
- Fixed a crash bug in ob_end_*() functions. ob_end_*() will not delete
buffers that may not be deleted. (Yasuo)
- Added 3rd parameter "bool erase" to ob_start(). If FALSE, the buffer may not
be deleted until script finishes. (Yasuo)
- Changed ob_*() functions to return TRUE for success, FALSE for failure.
(Yasuo)
- Added sybase_ct support to dbx module. (Marc)
- Fixed error message handling with PostgreSQL 7.2. (Rui)
- Added object aggregation capability, see aggregation_*() functions. (Andrei)
- Added debug_zval_dump() which works similarly to var_dump, but displays
extra internal information such as refcounts and true type names. (Jason)
- Added Andrei's tokenizer extension. (Stig)
- Fixed a bug in the COM extension which caused php to crash in
php_COM_get_ids_of_names(). (Paul, Harald)
- Removed ext/satellite. It is now part of PEAR. (eriksson)
- Changed php.ini directive 'safe_mode_include_dir' to accept a (semi)colon
separated path (like 'include_path') rather than a single directory.
(jflemer)
- Added is_a() function that can be used to test whether object is of a certain
class or is derived from it. (Andrei, Zend Engine)
- Added optional parameter to highlight_string() and highlight_file() which
makes these functions to return a highlighted string instead of dumping
it to standard output. (Derick)
- Added EXTR_IF_EXISTS and EXTR_PREFIX_IF_EXISTS flags to extract(). (Rasmus)
- Fixed a segfault in pg_pconnect(). If PostgreSQL server is restarted, broken
connection is detected and reconnected. (Yasuo)
- Fixed --enable-safe-mode configure option. (Yasuo)
- Added function domxml_dump_node($doc,$node). Dumps a node plus all children
into a string. (chregu)
- Added function domxml_node_get_content(). (chregu)
- Added function domxml_dump_file($filename,[$compression]). Dumps XML to
a file and uses compression, if specified. (chregu)
- Added exslt integration to domxml extension (http://exslt.org for details).
Configure with --with-dom-exslt[=DIR] (and --with-dom-xslt).
(chregu,jaroslaw)
- Fixed session_unset() to not touch any globals if register_globals is off.
(Thies)
- Added 3 new optional parameters to OCIFetchStatement(). They control
the number of rows to skip at the beginning of the cursor, the
maximun numer of rows that should be fetched and the format of the
returned array. (Thies)
- Updated the XSLT extension to support Sablotron 0.8. (Petr Cimprich)
- Fixed a bug in preg_match() and preg_match_all() when matching strings
contain null bytes. (Andrei)
- Added xpath_register_ns() function. This makes it possible to issue XPath
queries with namespaces like for example: "//namespace:sampletag".
(Chris Jarecki)
- Added multi-byte enabled regular expression functions. (Rui)
- Added optional second parameter to count() which can be used to specify
either normal or recursive counting. (patch by Vlad Bosinceanu <glipy@fx.ro>)
- Added mb_get_info() to get internal settings of mbstring. (Rui)
- Added async query functions to PostgreSQL module. (Yasuo)
- Added pg_copy_to()/pg_copy_from() for PostgreSQL module. (Youichi, Yasuo)
- Added IPv6 support for FTP extension. (Stig Venaas)
- Improved the speed of wordwrap() significantly. (Jim)
- Fixed pow()'s incorrect behaviour when dealing with powers of 0. (Jim)
- Added is_finite(), is_infinite() and is_nan(). (Jim)
- Fixed segfault in wordwrap() when wrapping to zero width and using
multi-character break or trying to force cut (bug #12768). (Jim)
- Fixed several bugs in dbase extension (dbase_pack() truncate file to right
size, fix 6852 #1 and 6852 #2). (Vlad)
- Fixed bug in krsort() where an extra character was being compared. (Andi)
- Fixed bug that made pspell include pspell.h from a wrong location. (Vlad)
- Added function overload in mbstring to add multibyte support for
string and mail functions. (Rui)
- Added flags parameter to preg_grep(). The only flag currently is
PREG_GREP_INVERT that will make the function return entries that
did not match. (Andrei)
- Fixed several crash bugs in the xslt extension. (Markus, Derick)
- Fixed problem with dbase not returning very large (larger than long)
integers properly. (Vlad)
- Added concepts to IRCG: bailout-on-trivial issue, write output to
files, fetch a resource upon connection end. (Sascha)
- Fixed POST-related bugs in thttpd, added QUERY_STRING, HTTP_HOST,
HTTP_ACCEPT_LANGUAGE to the script environment, improved patch
to send correct MIME types, and added support for /nocache/. (Sascha)
- Fixed several bugs and memleaks in the domxml extension. (Markus)
- Added var_export() which outputs a representation of a variable as reusable
PHP code. (Derick)
- Added -w option to the CGI-version to strip all comments and whitespace
from the script. (Thies)
- Added support for SO_RCVTIMEO and SO_SNDTIMEO to ext/sockets. (Jason)
- Added ob_get_level() which returns the nesting level of the output buffering
mechanism. (Yasuo, Derick)
- Added ob_flush() and ob_clean() functions which flush and clean an output
buffer without destroying the buffer. (Derick)
- Added new optional parameter to mysql_connect() which forces a new database
link to be created. (Markus, Derick)
- Added ldap_sort() function. (Stig Venaas)
- Added md5_file() function which calculates the MD5 sum of a file.
Patch by Alessandro Astarita <aleast@capri.it> (Derick)
- Added support for parsing recordsets contained in WDDX packets. (Andrei)
- Renamed key_exists() to array_key_exists(). (Derick)
- Fixed ImageColorsForIndex() and ImageColorAt() to work for TrueColor
images. (Rasmus)
- Added support for bind_textdomain_codeset(). (rudib@email.si)
- Added generic Win 32 API extension. (jmoore)
- Removed warning message about NONEXISTENT character set from mysql_connect()
when the server's default character set != latin1. (Mysql Team)
- Added Direct I/O extension for lowlevel access to the POSIX layer. (Sterling)
- Added SAPI module for the WebJames server on RISC OS. (Alex Waugh)
- Fixed ldap_add() and ldap_modify() functions to throw a warning with illegal
value arrays. Previously segfaulted or added wrong value. (Stig Venaas)
- Added udm_check_charset() function into mnoGoSearch extension. (gluke)
- Fixed mnoGoSearch extension to support mnogosearch-3.2.x. (gluke)
- Made fbsql_num_rows() to return the correct value on all select statements.
(Frank)
- Added array_chunk() function which splits an array into chunks of specified
size. (Andrei)
- Fixed $HTTP_RAW_POST_DATA to be populated on a missing content-type when
always_populate_raw_post_data is on. (Rasmus)
- Added session_cache_expire() function. (patch by anuradha@gnu.org) (Andrei)
- Added array_fill() function. (Rasmus)
- Made Authorization header to be hidden from phpinfo() output in safe_mode.
(Rasmus)
- Re-instated safe-mode realm mangling. (Rasmus)
- Fixed a bug in preg_replace() that would change the type of the replacement
array entries to string. (Andrei)
- Added user-space object overloading extension. (Andrei)
- Added ldap_start_tls() function. (Stig Venaas, patch by kuenne@rentec.com)
- Changed rand() and mt_rand() to be seed automatically if srand() or
mt_srand() has not been called. (Sterling)
- Changed the seed options to srand() and mt_srand() to be optional. If the
seed is not specified the most random seed possible is generated. (Sterling)
- Added array_change_key_case() function which returns an array with all
string keys lowercased or uppercased. (Edin)
- Added parameter to ircg_pconnect to suppress treating non-fatal errors
as fatal, and added conversion of Windows quotes to ". (Sascha)
- Added pcntl_exec() function which behaves similar to the system execve.
(Jason)
- Fixed segfault and check for truecolor image in ImageColorAt(). (Rasmus)
- Fixed nl2br() to handle all styles of line-endings in one string.
(Boian, Derick)
- Added mcrypt_generic_deinit() to replace mcrypt_generic_end(). (Derick)
- Added apache_setenv() function for injecting variables into Apache's
subprocess_env table. (Rasmus)
- Added support for 'int', 'bool', 'float' and 'null' in settype(). (Jeroen)
- Added IPv6 support to gethostbyaddr().
(Patch by Matthias Wimmer <matthias@charente.de> and venaas)
- Fixed LONG_VARCHAR type crashing in ODBC extension. Patch by Walter Franzini.
(kalowsky)
- Changed in_array() and search_array() to allow the needle to be an array
in itself. (Andrei)
- Added ini_get_all() function which returns all registered ini entries
or entries for the specified extension. (Jani)
- Added mailparse_uudecode_all() which extracts all uuencoded attachments.
(Wez)
- Added support for chinese encodings in htmlentities() and htmlspecialchars().
(Patch by Alan Knowles <alan_k@hklc.com> and Wez)
- Improved support for autoconf-2.50+/libtool 1.4b+. (Jan Kneschke, Sascha) |
Ermmm das leuk maar volgens mij komt dat pas in 4.3.0Op woensdag 03 april 2002 17:12 schreef Nielsz het volgende:
Sweet fixes
Wordt nog en enorme klus om over te stappen met me 2e project van 4.0.6 naar 4.1.X/4.2.X
Ik ben zo blij als een kind- Added flags parameter to preg_grep(). The only flag currently is
Ik ben dus bezig met een parser, en die kan alleen maar werken als zoiets bestaat, anders kan het niet
PerlNielsz: Ik ben dus bezig met een parser, en die kan alleen maar werken als zoiets bestaat, anders kan het nietop mijn manier
Wat is datOp vrijdag 05 april 2002 12:41 schreef tomato het volgende:
Perl![]()
Heel mooi dat het nu ook in de release zit. Ik benm al een tijdje aan het testen met de cvs versie en het gaat een stuk sneller dan sablotAdded exslt integration to domxml extension (http://exslt.org for details).
(chregu,jaroslaw)
Werkt het ook nog een beetje makkelijk danOp vrijdag 05 april 2002 18:49 schreef freak007 het volgende:
Jep, werkt super makkelijk. Hier is een lijstje met de nieuwe functies en hoe ze gebruikt kunnen worden.Op zaterdag 06 april 2002 15:44 schreef pinguin het volgende:
Werkt het ook nog een beetje makkelijk danModulaire opbouw ziet er in ieder geval mooi uit...
