"DivX box" barebone
  • SEFje
  • Laatst online: 09-03 11:51
Nee, geen casemod van mij, maar een poroduct wat in de winkel te koop is.
het leek me wel een interessant apparaat.
pic:
Afbeeldingslocatie: http://image.lik-sang.com/images//170/divx_cube.jpg
specs:
VIA VT8363A(PL133)
Supports Intel FCPGA Pentium III / Celeron (Celeron up to 1.1GHz with 128Kb and PIII up to 1.13GHz)
Two 168-pin PC100/PC133 SDRAM DIMM
Onboard Savage 2D/3D Graphics Engine
Onboard IEEE 1394 / USB interface
Onboard 10/100 Fast Ethernet
Onboard AC97 audio
S-video and composite TV-out terminal
Supports ATA 33/66/100 IDE Interface
Chassis: All aluminum
Drive bays: 5.25 X 1 / 3.5 X 2
Power Supply: 150W power supply (110/240V) with UL, CSA, TUV, and CE requirements
1 PCI slot
Riser Card: 1 (with 1 PCI slot)
VIA VT8604 North Bridge
Host interface
Integrated Savage4 2D/3D Graphics Engine
PC 133 SDRAM/VCM interface
PCI interface
ACPI Compliant
VIA VT82C686B South Bridge
UDMA 33/66/100 IDE interface
USB interface
Integrated Super I/O controller
Integrated hardware monitoring controller
Power management meet ACPI requirement
RTC
CPU: Socket 370 type CPU
Intel Celeron with 66MHz FSB (100MHz FSB for future CPU)
Intel Pentium III with 100 / 133MHz FSB
FSB 66 / 100 / 133MHz
Form Factor Flex ATX: 7" X 7.5"
Memory
DIMM x 2, Up to 1GB of 168-pin PC100 /PC133 SDRAM
Graphics
Built in Savage 4 graphics engine
On board 1394 chipset
Lucent FW323
1394a OHCI link and PHY in single package
Complies with 1394 OHCI specification revision 1.0
Provides three fully compliant cable ports
Support 400Mb/s, 200Mb/s, 100Mb/s data transfer rate
Ethernet
On board Realtek 8139C
IEEE 802.3u 100Base-T specifications compliant
10 Mb/s and 100 Mb/s operation
Supports Wake-On-LAN function
Expansion Bus
1 x PCI
PCI 2.2 specification compliant
I/O
Built in VIA 686B
Support 1 UART for Complete Serial Ports
Support 1 Multi-mode parallel port
Support 1 Floppy Disk Controller
Support PS2 keyboard and mouse
H/W Monitor
Built in VIA686B
Voltage, Temperature, Fan Speed Monitor
IDE
Ultra DMA 33/66/100 mode
PIO mode 4
2 IDE ports
Power Management
APM 1.2
ACPI 1.0
BIOS
Award PnP BIOS
DMI 2.3
2Mb flash memory
Back Panel Ports and Connectors
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA port
1 x Serial Port
1 x Parallel port, supports SPP, ECP, and EPP mode
2 x 1394 ports
1 x SVideo connector
1 x Composite connector
2 x USB ports
1 x RJ45 port
1 x line-in connector
1 x line-out connector
Other connectors and jumpers
2 x fan connectors
2 x Front Panel USB Connector Header
Front side line-out and mic-In Header
CD Audio in connector
Clear CMOS
1 x ATX power connector
Others Feature
CPU Voltage Auto Detecting (CPU PnP)
Support Suspend to Ram
Power on by Ring
Wake-On-LAN
Lijkt me wel een grappig dingetje, en hij is dus te koop bij Lik-Sang >> hier
Wat vinden jullie ervan?
PS: Hoe kan ik tekst kleiner maken? dan is die lap specs niet zo irritant...
Laat me raden: Search niet gebruikt??? Dit ding staat er al meerdere malen in nl.. :)
  • SEFje
Op dinsdag 02 april 2002 21:06 schreef us1111 het volgende:
hmmm...... search juist wel gebruikt...
niets gevonden; misschien verkeerd gezocht... :?
sorry iig :z
Stond al eens gepost maar is wel lachen om naast de video recorder onder de tv te hebben.
Heb um laatst gezien op een pc discount (ja daar durf ik te komen ;)) een geinig ding (vaker langsgekomen en op frontpage gestaan???) maar je moet wel fokking kleine vingers hebben wil je er een beetje bij kunnen :D En trouwens een pc in een video modden is toch origineler en leuker dan zo'n doosje naast de teevee te zetten toch?
  • SEFje
Op dinsdag 02 april 2002 21:12 schreef D_e_X het volgende:
nou ja je hoeft die caser in principe niet te houden, je kunt ook zelf gaan sleutelen :Y)
  • Thunder
met [sub]blaat[/sub] of [sup]blaat[/sup]
Wat voor OS zit er eigenlijk op ? Of is het gewoon CD erin gooien en het dingetje werkt?
  • SEFje
er zit nog geen OS op, ook geen CPU, geheugen of drives.
Je koopt alleen de kast met voeding en een mobo als ik het juist heb.
  • Dreamstar
  • Laatst online: 11-03 10:34
Idd, alleen kast, mobo en psu en cpu cooler.
Dat ding is dus gewoon een Shuttle SV24, en die is al heel vaak langsgekomen.
www.spacealker.com voor meer info
Is een leuk bakje. Keb hem zelf ook. Maakt alleen heel veek herrie met de bij geleverde koelers. Loopt voor de rest heel stabiel en is leuk om mee te werken. Keb er 1 dvd/combo, 20 gb 7200 rpm, 512 ddr, live plyer 5.1 en PIII 1000 in zitten. Alleen voor spellen is het niks
