Maxtrox G550 DualHead Problemen
Hallo allemaal,
Ik heb een probleem met mijn Matrox Millennium G550 DH.
Hieronder het probleem.
Mijn excusses dat het in het engels is, maar ik heb deze post ook op een international forum gedaan, dus vandaar.
Bij voorbaad dank.
Hi there,
Well I've got quite a difficult problem.
Here is my configuration:
Motherboard: Asus P3BF
Pentium III 450 Mhz
256 MB Internal Memory
Monitor 1: Ilyama 410 Pro
Monitor 2: Ilyama 410 Pro
TV: Philips 100 Hertz (PAL)
Matrox Millennium G550 Dual Head
Driverpackage: 5.71.014 (Drivers that came with the card)
OS: Windows 98 SE
Here is the situation on Problem NR 1:
I read on this forum that you should put your monitor on the DVI port of your Matrox card. Well when I do this, I do not see anything.
Status of pc at that time:
VGA port (2): Empty (none connected)
DVI Port (1): Ilyama (connected with the DVI-to-HD15 adapter/dongle)
Windows is running in Single Head modus.
Any suggestions how to make this work?
Problem NR 2:
Monitor on DVI does work but not fully when:
VGA port (2): TV connected (through a BOC, used the video output NOT s-video)
Windows is running in Dual Head (Clone) Modus.
What is the problem? Well the image presented on my monitor is greenish. The image on my TV is good, full colors.
Problem NR 3:
Situation:
VGA port (2): Ilyama 410 Pro (Direct connected)
DVI Port (1): Ilyama 410 Pro (connected with the DVI-to-HD15 adapter/dongle)
Windows is running ing Dual Head modus.
In any Dual Head status (Zoom, Clone, DVD Max or Multidesk) my monitor on the DVI port is the one that is seen as the second monitor (secondairy) instaid as the first (primairy)
But to my knowlidge is should be primairy right?
Extra information:
- All products are official matrox products. so the the DVI-to-HD15 adapter/dongle is from Matrox, The BOC is from Matrox and ofcourse the card itself is from Matrox.
Does anyone have a solution?
In advance: Thank you all very much!
Sorry verkeerd plaats voor dit topic geloof ik.
Je mag het verwijderen / verplaatsen.
  • JvS
  • Laatst online: 07:38
JvS
Ik heb hem zelf ook
>> vb
Bedankt voor het verplaatsen.
Problem solved.
De problemen zijn opgelost. Dus dit topic mag weg.
