Visual Basic update error, pls help me
  • 45 views sinds 30-01-2008
ik probeer uit louter code de access records te manipuleren. Alles werkt perfect, behalve records toevoegen geeft problemen.
de code is:
Option Explicit
Dim cnnADO As New ADODB.Connection
Dim comTADO As New ADODB.Command
Dim rsTADO As New ADODB.Recordset
Private Sub cmdEmail_Click()
Set outl = New InternetExplorer
outl.Visible = False
outl.Navigate "mailto:" & txtEmail
End Sub
Private Sub Form_Load()
cnnADO.Provider = "Microsoft.Jet.OLEDB.4.0"
cnnADO.ConnectionString = "telefoonlijst.MDB"
cnnADO.Open
comTADO.ActiveConnection = cnnADO
comTADO.CommandText = "SELECT * FROM telefoonlijst"
rsTADO.CursorLocation = adUseClient
rsTADO.CursorType = adOpenDynamic
rsTADO.LockType = adLockPessimistic
rsTADO.Open comTADO
Set MSHFlexGrid1.Recordset = rsTADO
ReadRecord
End Sub
Private Sub cmdNavigeer_Click(Index As Integer)
Dim SQLString As String
Dim SQLkey As String
With rsTADO
Select Case Index
Case 0 ' movefirst
.MoveFirst
Case 1 ' moveprevious
.MovePrevious
If .BOF Then .MoveFirst
Case 2 'movenext
.MoveNext
If .EOF Then .MoveLast
Case 3 ' movelast
.MoveLast
Case 4 'nieuw
.AddNew
Case 5 'bewaren
.Update
.MoveLast
PasFlexGridAan
MsgBox "nieuw records toegevoegd"
Case 6 'wissen
.Delete
.MoveNext
PasFlexGridAan
If .EOF Then
.MoveLast
End If
End Select
End With
ReadRecord
End Sub
Public Sub ReadRecord()
txtID = GetValue(rsTADO!RecordNummer)
txtVoornaam = GetValue(rsTADO!voornaam)
txtTV = GetValue(rsTADO!Tussenvoegsel)
txtNaam = GetValue(rsTADO![achternaam])
txtStraatnaam = GetValue(rsTADO!straatnaam)
txtHuisnummer = GetValue(rsTADO!Huisnummer)
txtPostcode = GetValue(rsTADO!Postcode)
txtWoonplaats = GetValue(rsTADO!woonplaats)
txtTelefoonnummer = GetValue(rsTADO!Telefoonnummer)
txtMobiel = GetValue(rsTADO![GSM-Nummer])
txtEmail = GetValue(rsTADO![E-mail adres])
End Sub
Private Function GetValue(TabelVeld As Field) As String
GetValue = IIf(IsNull(TabelVeld), Empty, TabelVeld)
End Function
Private Sub PasFlexGridAan()
Dim SQLcode As String, SQLkey As String
SQLkey = Val(Trim(txtID.Text))
SQLcode = "select * from telefoonlijst"
comTADO.CommandText = SQLcode
rsTADO.Requery
End Sub
Private Sub MSHFlexGrid1_Click()
rsTADO.Filter = ""
With MSHFlexGrid1
If .Col <> 1 Then .Col = 1
rsTADO.MoveFirst
rsTADO.Find ("recordnummer = " & Val(MSHFlexGrid1.Text))
ReadRecord
End With
End Sub
  • Janoz
  • Laatst online: 09-09 20:58
Janoz
Moderator Devschuur®
!litemod
Dit topic voldoet eigenlijk bij langena niet aan de eisen gesteld in de quickstart..
je hele source posten met de mededeling "Hij doet het niet" zijn we hier niet echt van gediend.
