CPU Ice - Een Overklokker's natte Droom
  • 50 views sinds 30-01-2008
  • Sjah
  • Laatst online: 23:39
Dit kwam ik net tegen op ZDNet:
"CPU Ice is a revolutionary new piece of software that actively cools your CPU.
Most modern CPU's can be sent into a suspend state using a HLT instruction, instead of generating idle cycles which keep the CPU busy and hot.
CPU Ice incorporates this new technology, but extends it further, allowing HLT commands to effectively be carried across the system bus, cooling virtually any device to benefit from this new technology.
We see this software primarily used in large corporate networks, where hardware life needs to be extended because of the cost of large scale roll outs. We also see a specific need for people who overclock their CPU's. We don't endorse overclocking, but its a fact of life, so why not cater for it ? CPU Ice has infact, a number of anti crash mechanisms in place, to allow high CPU multipliers and bus speeds to be obtained. Intel and AMD CPU's tend to crash on only one or two specific operations when overclocked, and usually in the same way, which means we can compensate for it, after running a built in diagnostic routine. (You only do this once)
We have happily overclocked AMD Athlon XP 1.6Ghz to 2.9Ghz, and achieved similar results with Intel processors."
CPU Ice is available for download at www.zdnet.net
  • Super_ik
  • Laatst online: 22:40
Super_ik
haklust!
uhh, dit is nie echt revolutionair hoor, :z deze halt instructies uitvoeren techniek is echt al jaaaaaaaaaaaaaaaaaaaaaaaaaaren oud hoor :{
8<------------------------------------------------------------------------------------
Als ik zo door ga haal ik m'n dood niet. | ik hou van goeie muziek
inderdaad kijk maar naar CPU cool dat doet hetzelfde... Bovendien kan zo je CPU op full load nog steeds bakken... En als ie te warm wordt en je draait net Max Payne ofzo dan gaat dat stotteren omdat die game toevallig net ff tien klokcycles meer wil en die krijgt ie dan een seconde te laat. Irritant want dat kost je veel fps en 3DMarks.
  • MRic3
  • Laatst online: 24-08 07:43
MRic3
Of praat ik weer poep?
Programma's zoals dat bestaan idd al langer en werken ook
(zit ook code in windows 2000/XP ingebakken)
Maar dit voorbeeld is extreem....
Wat is de datum dat het gepost is? 1 april?
En het is zdnet.com
If the world didn't suck, we would all fall off!!!
  • BlizzarD
BlizzarD
Hooooooh
Tralalalalaa
1 april, hoeveel van dat soort onzin krijgen we nog vandaag |:(
iStockphoto
  • SH007
Op maandag 01 april 2002 10:03 schreef BlizzarD het volgende:
Tralalalalaa
veel :(
  • Kaj.
Kaj.
1 LED is niet genoeg
teveel
