[mdk8.2] Divx, again.. codecs.conf?
  • JJJ
  • Laatst online: 16:16
Ik heb mplayer gecompiled met de volgende line:
./configure --prefix=/usr/local --enable-gui --enable-png --disable-runtime-cpudetection --enable-sdl --enable-x11 --enable-mmx --enable-3dnowex --with-win32libdir=/usr/lib/win32
Lijkt mij een goede line. Make en Make install gingen ook zonder problemen. Als ik nu op deze manier een filmpje wil afspelen:
mplayer /mnt/win_d/Anime/Noir/Noir\ -\ 22.avi
Dan krijg ik dit:
Requested video codec family [ffdivx] (vfm=5) not available (enable it at compile time!)
Opening Video Decoder: [odivx] DivX4Linux lib (odivx mode)
MPlayer interrupted by signal 11 in module: init_video_codec
- MPlayer crashed by bad usage of CPU/FPU/RAM. Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and disassembly. For details, see DOCS/bugreports.html section 5.b.
- MPlayer crashed. This shouldn't happen. It can be a bug in the MPlayer code _or_ in your drivers _or_ in your gcc version. If you think it's MPlayer's fault, please read DOCS/bugreports.html and follow instructions there. We can't and won't help unless you provide these informations when reporting a possible bug.
*** free_stream() called ***
Hoe los ik dit op? Ik zit hier al helemaal vast :|
[edit]
gcc --version geeft: 3.0.4
drivers: voor xfree 4.2.0: driver nv voor X.
mplayer -vo sdl blabla.avi
  • JJJ
Op zondag 31 maart 2002 15:00 schreef Felix het volgende:
Invalid video output driver name: sdl
-vo help geeft:
MPlayer CVS-020331-06:00-3.0.4 (C) 2000-2002 Arpad Gereoffy (see DOCS!)
CPU vendor name: AuthenticAMD max cpuid level: 1
CPU: Advanced Micro Devices Athlon TB Thunderbird (Type: 6, Stepping: 2)
extended cpuid-level: 6
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0
Compiled for x86 CPU with features: MMX MMX2 3DNow 3DNowEx
Available video output drivers:
xvX11/Xv
x11X11 ( XImage/Shm )
glX11 (OpenGL)
gl2X11 (OpenGL) - multiple textures version
dgaDGA ( Direct Graphic Access V2.0 )
fbdevFramebuffer Device
pngPNG file
nullNull video output
pgmPGM file
md5MD5 sum
mpegpesMpeg-PES file
yuv4mpegyuv4mpeg output for mjpegtools (to "stream.yuv")
vesaVESA VBE 2.0 video output
xvidixX11 (VIDIX)
  • JJJ
Okee, ik heb ff sdl gecompileerd en divx werkt nu _eindelijk_ :) De gui werkt alleen nog niet. Ik krijg eigenlijk geen errors.
[root@chidori jouke]# mplayer -gui
vo: X11 running at 1400x1050 with depth 16 and 16 bits/pixel (":0" => local display)
Reading /root/.mplayer/codecs.conf: 30 audio & 80 video codecs
Font /root/.mplayer/font/font.desc loaded successfully! (206 chars)
Linux RTC init error: Device or resource busy
Using usleep() timing
Input config file /root/.mplayer/input.conf parsed : 50 binds
SKIN dir 1: '/root/.mplayer/Skin'
SKIN dir 2: '/usr/local/share/mplayer/Skin'
Ik heb de fonts en de skins van mplayerhq.com gehaald, en gewoon in de maps gezet waar mplayer een error over gaf (dus waar hij zocht). Dat werkt alleen nog niet. Hoe fix ik dit?
  • foser
  • Laatst online: 26-06 15:03
Skins uitgepakt ? en hm, hij zoekt standaard voor de 'neutral' skin, dus die moet je iig hebben of in je config aangeven dat je een andere skin wilt gebruikten -> skin = <naam> (dacht ik). Dus je moet een pad hebben ~/.mplayer/Skin/neutral/* .
