Tux_NL
  • 40 views sinds 30-01-2008
Gentoo 1.0 is uit!
denk ik zeg et ff :)
Godver....sorry ben net wakker...topictitel is zoals misschien opgevallen niet echt goed...
  • jelmervos
jelmervos
Simple user
"The shell stopped unexpectedly and Explorer.exe was restarted."
  • intoxicated
intoxicated
Haaaai :w | ALT-S
Gaaf, en nu ook een ISO direct bij Gentoo vandaan halen met i686 binaries!
* intoxicated gaat 'm direct installeren. En straks ook KDE3 Final. En 1 mei Gnome 2.0 Final. En dan ben ik weer helemaal blij :P
"Anyone who does not agree with me is mentally sick, and should be shot I'm afraid to say."
- Pastor Richards @ VCPR
Woei
gentoo-1.0-i686.iso 31-Mar-2002 01:35 103M
gentoo-ix86-1.0.iso 31-Mar-2002 01:02 16.0M
stage1-ix86-1.0.tbz2 30-Mar-2002 22:22 7.8M
stage1-ix86-1.0.tbz2.md5 30-Mar-2002 23:06 1k
stage2-i686-1.0.tbz2 30-Mar-2002 22:30 27.9M
stage2-i686-1.0.tbz2.md5 30-Mar-2002 23:06 1k
stage3-i686-1.0.tbz2 30-Mar-2002 22:49 59.6M
stage3-i686-1.0.tbz2.md5 30-Mar-2002 23:06 1k
About these tarballs:
The "stage1" tarball is what we used to call a "build tarball". It is a chrootable image that you can use to build Gentoo Linux completely from scratch. It requires a bootstrap and an "emerge system" to convert it to a bootable Gentoo Linux system.
The "stage2" tarball is a build tarball that's been bootstraped for you. It only needs an "emerge system" to convert it to a bootable Gentoo Linux system. Handy if you want specific optimizations (such as i686) but want to change your USE variables significantly from the default.
The "stage3" tarball is a fully-built Gentoo Linux system. It has already been bootstrapped and emerge system has already been performed. You can simply extract this tarball to your root filesystems, configure and boot your new Gentoo Linux system. Very handy for when you want specific optimizations (i686)and the default USE settings are just fine (they usually are).
Note: The "i686" tarballs use "-O3 -march=i686" optimizations; they require a Pentium Pro or greater to use (K6 won't work). The "ix86" tarballs will work with anything, i486 or greateer.
You can find up-to-date install instructions at
http://www.gentoo.org/doc/build.html, or on the ISO image. To view the install docs on the ISO image, boot the CD and then type "less /install.txt".
Best Regards,
Daniel Robbins
Gentoo Technologies, Inc.
gentoo-dev@gentoo.org
Mjah, heel leuk natuurlijk dat Gentoo final gegaan is, maar het is meer iets voor de meuktracker ;)
NOS is niet echt bedoeld als een aankondigingenforum ;)
Je hebt de pech dat er de laatste tijd relatief veel van dit soort topics in NOS zijn en deze dus ook op slot gaat.
Voor dit soort dingen heb je de bekende sites en Tweakers.net's meuktracker ;)
