[Banner]link is dood :D
Wou kijken voor geheugen en nu blijkt dat deze banner dood is :
http://adserver.tweakers.net/banners/crucial/banner.gifThe page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
:P :D
  • Kaj.
Kaj.
1 LED is niet genoeg
ik zie 'm gewoon?
Op zondag 31 maart 2002 10:34 schreef Kaj. het volgende:
ik zie 'm gewoon?
Maar als je erop klikt doet ie het ni :P
  • We Are Borg
  • Laatst online: 21:48
We Are Borg
Moderator Wonen & Mobiliteit / General Chat
Op zondag 31 maart 2002 10:40 schreef Shaggy het volgende:
w0000000000t |:( :P
Op zondag 31 maart 2002 10:58 schreef We Are Borg het volgende:
w0000000000t |:( :P
w00000t , click daar dan ook ni op , das een voorbeeld van die banner :P , click erop op de frontpage of op het forum :* :P
  • We Are Borg
We Are Borg
Op zondag 31 maart 2002 11:07 schreef Shaggy het volgende:
Of gewoon niet op de banner klikken :P
Op zondag 31 maart 2002 11:13 schreef We Are Borg het volgende:
Wil graag geheugen bestellen en als ik op die banner click dan gaat 7% naar Tweakers.net vandaar.....
  • Kaj.
Kaj.
Zeg dat dan..
Topictitel ff aangepast :)
  • We Are Borg
We Are Borg
Op zondag 31 maart 2002 11:14 schreef Shaggy het volgende:
Okee, sorry, je hebt gelijk ;) Wie regelt dit allemaal, ICQ hem meteen :P
Op zondag 31 maart 2002 11:31 schreef Kaj. het volgende:
Zeg dat dan..
Kan ni zo goed uit mijn woorden komen :P
