MOHAA error
  • 137 views sinds 30-01-2008
  • T-8one
  • Laatst online: 13-10 10:38
T-8one
take it easy, take a sisi
als ik mohaa opstart om te gaan spelen, springt ie terug naar windows en sluit ie mohaa af net op het moment dat ie wil gaan laden.
ik krijg de volgende error melding in het console;
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
C:\games\MOHAA\main\Pak5.pk3 (259 files)
C:\games\MOHAA\main\Pak4.pk3 (593 files)
C:\games\MOHAA\main\Pak3.pk3 (669 files)
C:\games\MOHAA\main\Pak2.pk3 (4722 files)
C:\games\MOHAA\main\Pak1.pk3 (772 files)
C:\games\MOHAA\main\Pak0.pk3 (11175 files)
C:\games\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 408
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...29 PFDs found
...hardware acceleration found
...PIXELFORMAT 3 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_EXT_texture_compression_s3tc
...using GL_ARB_texture_compression
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...ignoring GL_EXT_texture_env_combine
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce2 MX/AGP
GL_VERSION: 1.3.0
GL_EXTENSIONS: GL_ARB_imaging
GL_EXTENSIONS: GL_ARB_multitexture
GL_EXTENSIONS: GL_ARB_texture_compression
GL_EXTENSIONS: GL_ARB_texture_cube_map
GL_EXTENSIONS: GL_ARB_texture_env_add
GL_EXTENSIONS: GL_ARB_texture_env_combine
GL_EXTENSIONS: GL_ARB_texture_env_dot3
GL_EXTENSIONS: GL_ARB_transpose_matrix
GL_EXTENSIONS: GL_S3_s3tc
GL_EXTENSIONS: GL_EXT_abgr
GL_EXTENSIONS: GL_EXT_bgra
GL_EXTENSIONS: GL_EXT_blend_color
GL_EXTENSIONS: GL_EXT_blend_minmax
GL_EXTENSIONS: GL_EXT_blend_subtract
GL_EXTENSIONS: GL_EXT_clip_volume_hint
GL_EXTENSIONS: GL_EXT_compiled_vertex_array
GL_EXTENSIONS: GL_EXT_draw_range_elements
GL_EXTENSIONS: GL_EXT_fog_coord
GL_EXTENSIONS: GL_EXT_packed_pixels
GL_EXTENSIONS: GL_EXT_paletted_texture
GL_EXTENSIONS: GL_EXT_point_parameters
GL_EXTENSIONS: GL_EXT_rescale_normal
GL_EXTENSIONS: GL_EXT_secondary_color
GL_EXTENSIONS: GL_EXT_separate_specular_color
GL_EXTENSIONS: GL_EXT_shared_texture_palette
GL_EXTENSIONS: GL_EXT_stencil_wrap
GL_EXTENSIONS: GL_EXT_texture_compression_s3tc
GL_EXTENSIONS: GL_EXT_texture_edge_clamp
GL_EXTENSIONS: GL_EXT_texture_env_add
GL_EXTENSIONS: GL_EXT_texture_env_combine
GL_EXTENSIONS: GL_EXT_texture_env_dot3
GL_EXTENSIONS: GL_EXT_texture_cube_map
GL_EXTENSIONS: GL_EXT_texture_filter_anisotropic
GL_EXTENSIONS: GL_EXT_texture_lod
GL_EXTENSIONS: GL_EXT_texture_lod_bias
GL_EXTENSIONS: GL_EXT_texture_object
GL_EXTENSIONS: GL_EXT_vertex_array
GL_EXTENSIONS: GL_EXT_vertex_weighting
GL_EXTENSIONS: GL_IBM_texture_mirrored_repeat
GL_EXTENSIONS: GL_KTX_buffer_region
GL_EXTENSIONS: GL_NV_blend_square
GL_EXTENSIONS: GL_NV_evaluators
GL_EXTENSIONS: GL_NV_fence
GL_EXTENSIONS: GL_NV_fog_distance
GL_EXTENSIONS: GL_NV_light_max_exponent
GL_EXTENSIONS: GL_NV_packed_depth_stencil
GL_EXTENSIONS: GL_NV_register_combiners
GL_EXTENSIONS: GL_NV_texgen_emboss
GL_EXTENSIONS: GL_NV_texgen_reflection
GL_EXTENSIONS: GL_NV_texture_env_combine4
GL_EXTENSIONS: GL_NV_texture_rectangle
GL_EXTENSIONS: GL_NV_vertex_array_range
GL_EXTENSIONS: GL_NV_vertex_array_range2
GL_EXTENSIONS: GL_NV_vertex_program
GL_EXTENSIONS: GL_SGIS_generate_mipmap
GL_EXTENSIONS: GL_SGIS_multitexture
GL_EXTENSIONS: GL_SGIS_texture_lod
GL_EXTENSIONS: GL_WIN_swap_hint
GL_EXTENSIONS: WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 2
PIXELFORMAT: color(16-bits) Z(16-bit) stencil(0-bits)
MODE: 3, 640 x 480 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU: x86 (P5/Pentium2, MMX)
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 2
texture bits: 16
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
Initializing Shaders
Setting up Shaders
----- finished R_Init -----
------- profiling DrawBackground methods -------
glDrawPixels w/ BGR: 13269 clocks
glDrawPixels w/ RGB: 12373 clocks
glTexSubImage2D w/ BGR: 4452422 clocks
glTexSubImage2D w/ RGB: 1987484 clocks
DrawBackground: using glDrawPixels with RGB data
------ Force Feedback Initialization -----
Loading ff...
ff: Creating feedback device:
ff: ...no ff mouse found
Failed to load ff dll
--------- Force Feedback Shutdown --------
Winsock Initialized
Opening IP socket: localhost:12203
Hostname: pc-finn
IP: 192.168.0.2
------- Sound Initialization (full) -------
Sound opened using Direct Sound
'Miles Fast 2D Positional Audio' provider opened.
Loading global/sound0.txt
------- S_StopAllSounds (stop music) -------
------- S_StopAllSounds Complete-------
----- Sound Info -----
driver - Miles Fast 2D Positional Audio
speaker setup - 2 speakers
reverb - OFF
samplebits - 16
speed - 22050
------- Sound Initialization Complete ------- 1006 ms
Setting up Shaders
Loading inventory...
----- Client Initialization Complete ----- 11323 ms
--- Common Initialization Complete --- 19603 ms
Working directory: C:\games\MOHAA
Loading Localization File global/localization.txt
------ Server Initialization ------
Server: briefing/briefing1
Setting up Shaders
UI_DrawConnect called
LoadLibrary("main/gamex86.dll") failed
...reason: 'Een apparaat dat op het systeem is aangesloten, werkt niet.
----- CL_Shutdown -----
------- Sound Shutdown (full) -------
------- Sound Shutdown Complete -------
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...hiding window
...destroying window
...window successfully destroyed
...resetting display
...shutting down QGL
...unloading OpenGL DLL
----- Server Shutdown -----
Couldn't load game
deze pc is een p 400 mhz, 320 mb, 32 mb geforce2, met windows 98.
wat is het probleem gldriver niet goed ofzow?
op m'n andere pc draait ie wel perfect.
bedankt/
GP 32 the most powerfull handheld in the world :P
  • SideSwipe
  • Laatst online: 13-10 23:58
SideSwipe
ZijZweep / SaaitSwiep !
Re-istall?
Trotse vader x 2!| Profiel volspammen mag hier: Klik
  • T-8one
T-8one
heb ik al drie keer geprobeerd, was ik zelf ook al op gekomen.
  • Warfare
  • Laatst online: 11-09 09:01
Probeer de laatste detonater es...
Moet werken...
  • Dennahz
  • Laatst online: 13-10 14:45
Dennahz
Life feels like hell should.
hmm volgens mij is dat een opengl fout..
probeer het volgende :
- instaleer de nieuwste directx
- instaleer de detenators
dat moet lukken :)
suc6
Twitter
Heb ik vaker gezien :)
Zoek maar eens goed ;)
Verder denk ik dat je in het grote Mohaa topic de meeste kans maakt op antwoorden :)
