Quote uit MSDN Library:
OpenSchema Method - ADO
Obtains database schema information from the provider.
Applies To
Connection
Syntax
Set recordset = connection.OpenSchema (QueryType, Criteria, SchemaID)
Return Values
Returns a Recordset object that contains schema information.
Parameters
QueryType The type of schema query to run. Can be any of the constants listed below.
Criteria Optional. An array of query constraints for each QueryType option, as listed below. QueryType values Criteria values
adSchemaAsserts CONSTRAINT_CATALOG
CONSTRAINT_SCHEMA
CONSTRAINT_NAME
adSchemaCatalogs CATALOG_NAME
adSchemaCharacterSets CHARACTER_SET_CATALOG
CHARACTER_SET_SCHEMA
CHARACTER_SET_NAME
adSchemaCheckConstraints CONSTRAINT_CATALOG
CONSTRAINT_SCHEMA
CONSTRAINT_NAME
adSchemaCollations COLLATION_CATALOG
COLLATION_SCHEMA
COLLATION_NAME
adSchemaColumnDomainUsage DOMAIN_CATALOG
DOMAIN_SCHEMA
DOMAIN_NAME
COLUMN_NAME
adSchemaColumnPrivileges TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
GRANTOR
GRANTEE
adSchemaColumns TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
adSchemaConstraintColumnUsage TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
adSchemaConstraintTableUsage TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
adSchemaForeignKeys PK_TABLE_CATALOG
PK_TABLE_SCHEMA
PK_TABLE_NAME
FK_TABLE_CATALOG
FK_TABLE_SCHEMA
FK_TABLE_NAME
adSchemaIndexes TABLE_CATALOG
TABLE_SCHEMA
INDEX_NAME
TYPE
TABLE_NAME
adSchemaKeyColumnUsage CONSTRAINT_CATALOG
CONSTRAINT_SCHEMA
CONSTRAINT_NAME
TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
adSchemaPrimaryKeys PK_TABLE_CATALOG
PK_TABLE_SCHEMA
PK_TABLE_NAME
adSchemaProcedureColumns PROCEDURE_CATALOG
PROCEDURE_SCHEMA
PROCEDURE_NAME
COLUMN_NAME
adSchemaProcedureParameters PROCEDURE_CATALOG
PROCEDURE_SCHEMA
PROCEDURE_NAME
PARAMTER_NAME
adSchemaProcedures PROCEDURE_CATALOG
PROCEDURE_SCHEMA
PROCEDURE_NAME
PARAMTER_TYPE
adSchemaProviderSpecific See Remarks
adSchemaProviderTypes DATA_TYPE
BEST_MATCH
adSchemaReferentialConstraints CONSTRAINT_CATALOG
CONSTRAINT_SCHEMA
CONSTRAINT_NAME
adSchemaSchemata CATALOG_NAME
SCHEMA_NAME
SCHEMA_OWNER
adSchemaSQLLanguages <none>
adSchemaStatistics TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
adSchemaTableConstraints CONSTRAINT_CATALOG
CONSTRAINT_SCHEMA
CONSTRAINT_NAME
TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
CONSTRAINT_TYPE
adSchemaTablePrivileges TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
GRANTOR
GRANTEE
adSchemaTables TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
TABLE_TYPE
adSchemaTranslations TRANSLATION_CATALOG
TRANSLATION_SCHEMA
TRANSLATION_NAME
adSchemaUsagePrivileges OBJECT_CATALOG
OBJECT_SCHEMA
OBJECT_NAME
OBJECT_TYPE
GRANTOR
GRANTEE
adSchemaViewColumnUsage VIEW_CATALOG
VIEW_SCHEMA
VIEW_NAME
adSchemaViewTableUsage VIEW_CATALOG
VIEW_SCHEMA
VIEW_NAME
adSchemaViews TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
SchemaID The GUID for a provider-schema schema query not defined by the OLE DB 1.1 specification. This parameter is required if QueryType is set to adSchemaProviderSpecific; otherwise, it is not used.
Remarks
The OpenSchema method returns information about the data source, such as information about the tables on the server and the columns in the tables.
The Criteria argument is an array of values that can be used to limit the results of a schema query. Each schema query has a different set of parameters that it supports. The actual schemas are defined by the OLE DB specification under the "IDBSchemaRowset" interface. The ones supported in ADO 1.5 are listed above.
The constant adSchemaProviderSpecific is used for the QueryType argument if the provider defines its own non-standard schema queries outside those listed above. When this constant is used, the SchemaID argument is required to pass the GUID of the schema query to execute. If QueryType is set to adSchemaProviderSpecific but SchemaID is not provided, an error will result.
Providers are not required to support all of the OLE DB standard schema queries. Specifically, only adSchemaTables, adSchemaColumns and adSchemaProviderTypes are required by the OLE DB specification. However, the provider is not required to support the Criteria constraints listed above for those schema queries.
Remote Data Service Usage The OpenSchema method is not available on a client-side (ADOR) Connection object.
Examples
OpenSchema Method Example (VB)
See Also
Using OLE DB Providers with ADO
