Preformance problemen op exchange v5.5
Wie kan me vertellen wat het onderstaande is,
deze melding verschijnt om de seconde.
Perflib melding :
The Open Procedure for service "AVExch32Service" in
DLL "GSPerf.dll" failed.  Performance data for this service
will not be available. Status code  returned is DWORD 0.
En ja ik weet dat het de preformance counters van
netshield betreft. Alleen waarom de melding en hoe
optelossen.
  • paulhekje
  • Laatst online: 23-10 09:19
wat is het event nummer?
|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
Op woensdag 27 maart 2002 10:43 schreef paulhekje het volgende:
1008,
ps. perflib gebruikt 1000 1001 1008 & 2002
  • paulhekje
www.eventid.net geeft deze oplossing:
McShield - dssdata.dll - R.M.: "You may recieve an error in event viewer about Mcaffe''s Perfmon Counter''s under NT4 Terminal server. To fix, research the following SolutionID: nai6288 under Mcaffe''s web site.
Op woensdag 27 maart 2002 11:17 schreef paulhekje het volgende:
Het is niet de oplossing van mijn probleem, zie onder.
PrimeSupport® KnowledgeBase
SolutionID: nai6288
Problem Description:
Error: "The Open Procedure for service "McShield" in DLL "dssdata.dll" failed.  Performance data for this service will not be available. Status code returned is DWORD 0."
Event ID 1008
In NT Event Viewer:
Event ID: 1008
Source: Perflib
Type: Error
Description:
View NetShield performance counters in performance monitor on Terminal Server 4.0
Problem Environment:
McAfee NetShield 4.5
Microsoft Windows NT Terminal Server
Cause of this problem:
The NetShield performance counters are not loaded into Terminal Servers properly on install.
Solution:
1. From a command prompt, change to the NetShield 2000 program directory.
If the default was not changed during setup, this will be C:\Program Files\Network Associates\NetShield 2000\
    2. Type  LODCTR DSSDATA.INI
This will install the NetShield performance counters and should resolve these errors on Microsoft Windows NT Terminal Server.
kick :+
  • Zwelgje
  • Laatst online: 17-08 09:02
welke versie van groupshield heb je?
kheb zelf ook een 5.5 server onder beheer die met versie 4.5 niet goed werkt (kan ook 5.0 zijn..)
met versie 4.0 doet ie het echter weer perfect, ik had toen bij versie 4.5 ook last van dat ie elke seconde een dll melding in de eventlog schreef en dat er in tegenstelling tot wat het programma beweerde GEEN virussen werden tegengehouden!!
Sp 4 eroverheen gehaald?
  • Zwelgje
Op zondag 31 maart 2002 10:50 schreef SuperMouse het volgende:
ik wel, maakte bij mij niks uit, maar mischien bij de topicstarter wel :)
