geforce 1 sdram botleneck ?
  • 101 views sinds 30-01-2008
ik haal met een 1ghz t-bird en een asus geforce1 sdram dit
3DMARK 2000 PROJECT FILE
PROJECT
Description: My Project
Comment:
3DMark Version: 340
Install ID: 0x55B95F95
Registration Key:
Registration Name:
TEMPLATE
Display:
Type: Internal
Width: 1024
Height: 768
Depth: 16-Bit
Buffering: Triple
Z-Buffering: 16-Bit
Refresh Rate: VSync Off
Texture Format: 16-Bit
Options:
Continuous Benchmark: No
Show Title Screens: Yes
Benchmark Run Count: 1
Continuous Demo Mode: No
Sounds Enabled: Yes
CPU Optimization: D3D Hardware T&L
RESULTS
Platform: Internal
3DMark Result: 5179 3D marks
CPU Speed: 449 CPU 3D marks
Game 1 - Helicopter - Low Detail: 111,4 FPS
Game 1 - Helicopter - Medium Detail: 78,9 FPS
Game 1 - Helicopter - High Detail: 35,9 FPS
Game 2 - Adventure - Low Detail: 93,0 FPS
Game 2 - Adventure - Medium Detail: 69,0 FPS
Game 2 - Adventure - High Detail: 43,4 FPS
Fill Rate (Single-Texturing): 357,8 MTexels/s
Fill Rate (Multi-Texturing): 585,6 MTexels/s
High Polygon Count (1 Light): 7900 KTriangles/s
High Polygon Count (4 Lights): 6982 KTriangles/s
High Polygon Count (8 Lights): 3983 KTriangles/s
8MB Texture Rendering Speed: 281,0 FPS
16MB Texture Rendering Speed: 263,4 FPS
32MB Texture Rendering Speed: 192,5 FPS
64MB Texture Rendering Speed: 95,2 FPS
Bump Mapping (Emboss, 3-pass): 142,5 FPS
Bump Mapping (Emboss, 2-pass): 190,2 FPS
Bump Mapping (Emboss, 1-pass): 322,5 FPS
Bump Mapping (Environment): Not supported FPS
SYSTEM
Software Versions:
Windows Version Windows 4 A , Build 2222
DirectX Version 4.07.00.0716
Bios Version Award Modular BIOS v6.00PG
Bios Date 07/28/00
Memory:
Total Physical Memory 128MB
Free Physical Memory 65MB
PROCESSOR
CPU Information:
Processor Type AMD Athlon(tm) Processor
Processor Speed 1000MHz
Processor Caps Enhanced 3DNow!/MMX
Cache Memory:
L1 Cache Size 128KB
L2 Cache Size 256KB
DESKTOP
2D Display Adapter:
Name NVIDIA GeForce 256
Driver Date 9-10-2000
Monitor:
Name Iiyama A201HT, VisionMaster Pro 510
Driver Date 10- 6-1999
Desktop Size and Color Depth:
Width 1280
Height 1024
Color Depth 16 bit
INTERNAL 3D CARD
Information:
Driver Name NVDD32.DLL
Driver Version 4.12.01.0626 (Certified)
Total Video Memory 32474KB
Total Texture Memory 87258KB
Minimum Texture Resolution 1 * 1
Maximum Texture Resolution 2048 * 2048
Maximum Texture Blending Stages 8
Maximum Texture Coordinates 8
Bus AGP
Manufacturer Identifier 0x000010DE
Chipset Type 0x00000100
Subsystem Identifier 0x40081043
Chipset Revision Level 0x00000010
Supported features:
Transformation and lighting in hardware Yes
16-Bit Rendering Yes
24-Bit Rendering No
32-Bit Rendering Yes
Textures In Single Pass 2
Driver can disable VSync by software request Yes
Edge Antialiasing No
Subpixel Accuracy Yes
Point Sampling Yes
Point Sampling With Mip-Mapping Yes
Bilinear Filtering Yes
Bilinear Filtering With Mip-Mapping Yes
Trilinear Filtering Yes
Anisotropic Filtering Yes
Specular Gouraud Yes
Vertex Fog Yes
Range Fog Yes
Table Fog No
W-Fog Yes
Alpha Blending Yes
Vertex Alpha Blending Yes
Vertex And Texture Alpha Blending Yes
Additive Alpha Blending Yes
Multiplicative Alpha Blending Yes
S3 Texture Compression Yes
DX6 Bump Mapping No
Flags:
DirectDraw flags 1 0x94C27FE3
DirectDraw flags 2 0x004AFE7D
Texture operations 0x009FFFFF
Stencil-buffer operations 0x000000FF
Miscellaneous capabilities 0x00000072
Raster capabilities 0x00376CA1
Z-comparison capabilities 0x000000FF
Alpha-test-comparison capabilities 0x000000FF
Source-blending capabilities 0x00001FFF
Destination-blending capabilities 0x00001FFF
Shading capabilities 0x000C528F
Texture capabilities 0x00000C0F
Texture-filtering capabilities 0x0703073F
Texture-blending capabilities 0x000000FF
Texture-addressing capabilities 0x00000017
Modes:
Z-Buffer formats 16-Bit Z-Buffer, 24-Bit Z-Buffer, 32-Bit Z-Buffer (8-Bit Stencil)
8-Bit Texture formats N/A
15-Bit Texture formats 15-bit, 555 RGB
16-Bit Texture formats 16-bit, 5551 RGBA, 16-bit, 4444 RGBA, 16-bit, 565 RGB
24-Bit Texture formats 24-bit, 888 RGB
32-Bit Texture formats 32-bit, 8888 RGBA
Display modes 320 * 200, 8 bit, 320 * 240, 8 bit, 400 * 300, 8 bit, 480 * 360, 8 bit, 512 * 384, 8 bit, 640 * 400, 8 bit, 640 * 480, 8 bit, 800 * 600, 8 bit, 960 * 720, 8 bit, 1024 * 768, 8 bit, 1152 * 864, 8 bit, 1280 * 720, 8 bit, 1280 * 960, 8 bit, 1280 * 1024, 8 bit, 1600 * 900, 8 bit, 1600 * 1200, 8 bit, 1920 * 1080, 8 bit, 1920 * 1200, 8 bit, 1920 * 1440, 8 bit, 2048 * 1536, 8 bit, 320 * 200, 16 bit, 320 * 240, 16 bit, 400 * 300, 16 bit, 480 * 360, 16 bit, 512 * 384, 16 bit, 640 * 400, 16 bit, 640 * 480, 16 bit, 720 * 480, 16 bit, 720 * 576, 16 bit, 800 * 600, 16 bit, 960 * 720, 16 bit, 1024 * 768, 16 bit, 1152 * 864, 16 bit, 1280 * 720, 16 bit, 1280 * 960, 16 bit, 1280 * 1024, 16 bit, 1600 * 900, 16 bit, 1600 * 1200, 16 bit, 1920 * 1080, 16 bit, 1920 * 1200, 16 bit, 1920 * 1440, 16 bit, 2048 * 1536, 16 bit, 320 * 200, 32 bit, 320 * 240, 32 bit, 400 * 300, 32 bit, 480 * 360, 32 bit, 512 * 384, 32 bit, 640 * 400, 32 bit, 640 * 480, 32 bit, 720 * 480, 32 bit, 720 * 576, 32 bit, 800 * 600, 32 bit, 960 * 720, 32 bit, 1024 * 768, 32 bit, 1152 * 864, 32 bit, 1280 * 720, 32 bit, 1280 * 960, 32 bit, 1280 * 1024, 32 bit, 1600 * 900, 32 bit, 1600 * 1200, 32 bit, 1920 * 1080, 32 bit, 1920 * 1200, 32 bit, 1920 * 1440, 32 bit, 2048 * 1536, 32 bit
vogens mij ligt dit aan de geforce of niet?
  • reapher
  • Registratie: Augustus 1999
  • Laatst online: 15-08 15:31
reapher
Z POWER
jazeker die gf1 is de bottleneck maar bij deze cpu is zelfs de gf2 de bottleneck
Click hier niet
"Fill Rate (Multi-Texturing): 585,6 MTexels/s"
wat een bullshit
een geforce 1 heeft een filrate limit van 480 MTexels/s
of je moet em hebben opgefokt
  • knights16
  • Laatst online: 22:05
je hebt gelijk ja,
maar je 3dMark score is echt wel netjes ofzow!
PVoutput
yep de core loopt op 150 en mem op 210
standaart op 120 en 166
niemand ?
