[ASP] waarden doorsturen
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
Set connectionToDatabase=Server.CreateObject("ADODB.Connection")
connectionToDatabase.ConnectionTimeout=60
connectionToDatabase.Open "DSN=test"
Set recordSet=Server.CreateObject("ADODB.Recordset")
recordSet.Open "Select * from voorstelling", connectionToDatabase,1,2
if response.IsClientConnected =  true then
if frminvAantal = "" and frmradio= "" then
response.write("<center><table border=1><tr><th>Voorstelling</th><th>Datum</th><th>Tijd</th></tr>")
Do While Not recordSet.EOF
response.write("<form action='test8a.asp' method='post'>")
response.write("<tr>")
response.write("<td>" & recordSet("Naam") & "</td>")
response.write("<td>" & recordSet("Datum") & "</td>")
response.write("<td>" & recordSet("Tijd") & "</td>")
response.write("<td><input type='radio' name='radio' value='" & recordSet("ID_voorstelling") & "'></td>")
response.write("</tr>")
------>session.contents("Naam") = recordSet("Naam")<------
recordset.MoveNext
loop
response.write("Aantal: <select name='invAantal'>")
response.write("<Option value='1'>1</option>")
response.write("<Option value='2'>2</option>")
response.write("<Option value='3'>3</option>")
response.write("<Option value='4'>4</option>")
response.write("<Option value='5'>5</option>")
response.write("<Option value='6'>6</option>")
response.write("<Option value='7'>7</option>")
response.write("<Option value='8'>8</option>")
response.write("<Option value='9'>9</option>")
response.write("<Option value='10'>10</optiom>")
response.write("</select>")
response.write("</table></center>")
response.write("<br><center><input type='submit' name='edit' value='ok'></center></form>")
 else
Display= "Select sum(aantal) as Aantal from reservering left join voorstelling on voorstelling.ID_voorstelling = reservering.ID_voorstelling where naam = ---->'" & session.contents("Naam") & "'<---- "
set recordSet = connectionToDatabase.Execute(Display)
response.write (Display)
end if
else
response.end
end if
ConnectionToDatabase.Close
Set ConnectionToDatabase=Nothing
De waardes session.contents("Naam") = recordSet("Naam") wordt niet weergegeven in de SQL statement. (aangegeven met pijltjes)
Ik kies een voorstelling m.b.v de radio button, daaraan vast zit de kolomnaam ID_voorstelling (die wordt naar de volgende pagina gestuurt. Maar de waarde die in kolomnaam Naam zit (recordSet("Naam") wordt niet weergegeven in de sql statement.
Vage beschrijving, maar ja. :?
Ik hoop dat het een beetje duidelijk is.
  • Greyfox
  • Laatst online: 08-09 21:20
Greyfox
MSX rulez
Misschien is
recordSet("Naam")
leeg?
MSX 2 rulez more
Op dinsdag 26 maart 2002 16:14 schreef Greyfox het volgende:
Misschien is
recordSet("Naam")
leeg?
oeps wat vergeten erbij te zeggen, hij haalt gegevens uit de tabel voorstelling. Als ik een voorstelling kies geeft de sql statement elke keer dezelfde waarde.
Dus de regel (14 ofzo?)
laat wel een waarde zien?
Je krijgt verder ook geen foutmelding te zien? Misschien is de session nog niet gevuld als je hem uitleest. Als je nu eens naar een pagina gaat en daar de session("naam") laat zien...
Suc6
Op dinsdag 26 maart 2002 16:25 schreef vanDee het volgende:
Suc6
Die waarde uit recordSet("Naam") die laat hij zien.
En bij session.contents("Naam") laat hij de waarde zien die onderaan de tabel staat, ook al geef je een andere waarde aan.
Op dinsdag 26 maart 2002 16:27 schreef msoete het volgende:
Ja dat laat hij zien.
Klopt de onderste waarde uit de tabel wordt in de sessie gedouwd. Maar waarom gebruik je een sessie en niet gewoon een variabele
Op dinsdag 26 maart 2002 16:35 schreef vanDee het volgende:
Omdat die anders de waarde niet onthoud die ik weer gebruik in de sql statement.
mmmm, stom van me |:( , na even goed te kijken naar mijn asp code, heb ik het probleem opgelost.
die waarde die ik doorstuur in mijn radio button (recordSet("ID_voorstelling") gebruik ik in mijn sql statement.
Het enige wat ik wilde is dat wat ik kies in m.b.v de radio button, dat die ook terecht komt in de sql statement.
Ik probeerde het moeilijk te doen door een andere kolomnaam te gebruiken.
ach
al doende leert men
thanx voor de replies (daardoor begon ik wat logischer te denken :) )
Ooooooh, zeg dat dan, dan ken je toch ook de
Request.Form("radio")
uitlezen.
't is ook wel een beetje 'vreemde' code :? Maar ja ieder z'n eigen code-style 8-)
Op dinsdag 26 maart 2002 17:10 schreef vanDee het volgende:
uitlezen.
Over dat uitlezen van die request.form("Radio") heb ik geen verstand van. (ben pas begonnen met ASP)
Zal ik je snel uitleggen dan.
Als je via een form iets submit dan kun je dat met Request uitlezen op de pagina waarnaar toe de action verwijst.
test1.asp:
<html>
   <head>
    <title>Blaat</title>
   </head>
   <body>
    <form action="test2.asp" method="post">
       <input type="text" name="blaat">
       <input type="submit">
    </form>
   </body>
</html>
test2.asp:
<html>
   <head>
   </head>
   <body>
    mijnVar = Request("blaat")
    Response.Write(mijnVar)
   </body>
</html>
Als ik nu bij test1.asp 'Hallo wereld' ( :P) invoer komt en ik druk op Submit dan komt er in test2.asp Hallo Wereld te staan.
Dus als er in een form een name bij een input (of select/textarea) staat kun je die uitlezen met Request("name v/d input").
Snappie vous 8-)
