wie kan deze verbinding voor mij omzetten ??? ben zelf aan t kloten geweest en t wil maar niet lukken:
om te zetten code
Server.ScriptTimeout = 50000
Set upl = Server.CreateObject("SoftArtisans.FileUp")
if upl.ContentType = "image/gif" or upl.ContentType = "image/pjpeg" or upl.ContentType = "audio/mpeg" or upl.ContentType = "application/x-zip-compressed" or upl.ContentType = "application/msword" then
NewFileName = Mid(upl.UserFilename, InstrRev(upl.UserFilename, "\") + 1)
Description = replace(Upl.Form("Description"),"'","''")
Size = upl.TotalBytes
upl.SaveinVirtual NewFileName
Set Conn = Server.CreateObject("ADODB.Connection")
Conn.ConnectionString = "DSN=DMG"
Conn.open
sql = "Insert into Files (Name,Description,Size,Uploader,Dateuploaded) Values ('" & NewFileName & "','" & Description & "','" & Size & "'," & Session("memberid") & ",'" & now & "')"
Conn.execute sql
Conn.close
Set Conn = Nothing
set upl = nothing
end if
response.redirect("../uploadfile.asp")
[/code]
mijn verbinding
Dim DB_CONNSTRING
DB_CONNSTRING = "DRIVER={Microsoft Access Driver (*.mdb)};DBQ=" & Server.Mappath("Admin/Database/Database_algemeen.mdb") & ";"
Dim rsCount ' The recordset object
Set rsCount = Server.CreateObject("ADODB.Recordset")
' rsCount.Open "onderdelen" ---> zoekt naar de betreffende tabel.
rsCount.Open "onderdelen", DB_CONNSTRING, adOpenStatic, adLockReadOnly, adCmdTable
Response.Write rsCount.RecordCount
Response.Write " Onderdelen in onze database." & vbCrLf
[/code]
thnx
om te zetten code
Conn.open
Conn.execute sql
Conn.close
Set Conn = Nothing
set upl = nothing
end if
[/code]
mijn verbinding
Dim DB_CONNSTRING
[/code]
thnx
