Radeon 7500 en Mohaa
  • 38 views sinds 30-01-2008
  • Priyantha Bleeker
  • Laatst online: 20-09 13:58
Priyantha Bleeker
Out and proud \o/ :D \o/
Ik heb een probleem met Mohaa en mijn radeon 7500.
Ik heb al met de search gezocht en gegoogled maar kon niet echt iets vinden helaas.
Ok nu mijn probleem hij zegt dat die iets van OpenGL niet kan vinden.
dit is de fout melding:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Jan 28 2002
----- FS_Startup -----
Current search path:
C:\Program Files\EA GAMES\MOHAA\main\Pak6Nl.pk3 (475 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak5.pk3 (259 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak4.pk3 (593 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak3.pk3 (669 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak2.pk3 (4722 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak1.pk3 (396 files)
C:\Program Files\EA GAMES\MOHAA\main\Pak0.pk3 (11174 files)
C:\Program Files\EA GAMES\MOHAA/main
18288 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 135
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...23 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
  • Dreamstar
  • Laatst online: 11-03 10:34
Dan zou er iers mis moeten zijn met je opengl drivers, je kaart ondersteund het iig wel (bijna alle ati's)
Ik d8 dat www.glsetup.com een progje (glsetup) had om losse opengl drivers er bij te installeren, probeer dat ff
Of gewoon dezelfde/nieuwere drivers herinstalleren
[search=could not load OpenGL subsystem]
