MOHAA 1.11 is uit.
  • KillerAce_NL
KillerAce_NL
If it ain't broke...
Dit is 1.11 voor US en UK versies:
Patch 1.11
- Stand-alone game server that runs without CD, mohaa_server.exe.
- Fixed bug in pak file search order
- Fix for spaces in rcon commands, fix for rcon data transmission
- Fix for rcon status command
- Fix for the dial-up networking problem when playing single-player.
- Fix for in-game server browser always auto-refreshing
- In-game browser shows version information on incompatible servers, and sorts incompatible servers to the bottom
- Fix for running servers from machines with multiple IPs
- After reaching an error screen from the in-game browser the game goes back to the browser, rather than main menu
- Fixed lag when a bomb was planted and the entire planting team was killed
- net_ip reflects what ip is actually used for the game
- gamespy uses the ip set with net_ip, if any
- Can follow players from the other team when your entire team is killed
- The multiplayer dial-up connection fix.
- sv_privatePassword and sv_privateClients work to reserve spots for admins
- Added proper disconnect and error screen display for when game refuses client connection
- Muzzle flashes stick to weapons.
- Localization code rolled in (and new localization file to work with altered system)
- Removed old Q3 skin code to save memory
- Fixed rare visibility glitch with lean
- Fixed rare instance when AI would suicide with grenades
- Fixed rare instance when an effect would flicker
- When a server drops below sv_fps clients get a "slow server" message. This shows up in single-player developer mode. Disable message by setting cg_drawsvlag to 0.
- Dynamic light fix for better spotlights
- Added protection against malicious names in multi-player
- Spectators can no longer telefrag players
- Fixed bug with forcemodel and spectator
- Strings are now localized as entire sentences, using &&& as a non-localizing wildcard match
- Fixed some memory leaks
Pak em hier:
ftp://ftp.ea.com/pub/ea/patches/mohaa/MOHAA_UKUS_ONLY_patch111v9safedisk.exe
Aan de filenaam te zien, is de update voornamelijk tegen no-cd cracks (safedisk protectie).
Jammer, die onder de grond bug is er niet uit....
Uhm, is dit geen serverpatch?
  • KillerAce_NL
KillerAce_NL
Nee.
Dacht het niet, maar ik heb ook pas net het nieuws binnen.
Ik hoop dat we nu niet weer allemaal incompatible versions gaan kijgen.
  • Fuelke
  • Laatst online: 23:31
Fuelke
Forza Ferrari
Normaal gezien komt er vandaag een NL-patch uit, is daar al nieuws over?
La Ferrari più bella è quella che dobbiamo ancore fare: La Prossima
  • KillerAce_NL
KillerAce_NL
Op vrijdag 22 maart 2002 09:48 schreef Fuelke het volgende:
Staat iig niet op de ftp. Afwachten dus.
als ie wel komt dan is dat lekker:
NL : 1.2
UK en US : 1.11
Rare jongens die EA gasten...
  • GandalfTheGrey
  • Laatst online: 19-09 09:13
GandalfTheGrey
Remember, Remember..
lijkt ook wel de server patch inderdaad.. op mohaa.ea.com zie ik er niks over..
Computer Specs
  • KillerAce_NL
KillerAce_NL
Kijk maar op msgsboard op mohaa.ea.com
Maar idd nog geen officiele melding.
Ik vind het een rare gang van zaken.
  • GandalfTheGrey
GandalfTheGrey
'tja.. ik w8 op een officiele mededeling, ga niet zomaar Patches installeren....
Computer Specs
  • KillerAce_NL
KillerAce_NL
Het komt wel van hun ftp af, hhm die fix ga je toch niet uploaden voordat je de site hebt aangepast?
Nee deze is cker niet officieel. Op geen officiele MOHAA site is deze patch te vinden dus......
  • KillerAce_NL
KillerAce_NL
Op vrijdag 22 maart 2002 10:40 schreef ThaNobius het volgende:
Kijk ff joh, hij staat op de ftp van EA. Is vannacht geplaatst.
  • Zephyer
  • Laatst online: 13-10 21:32
Ik wacht de 1e reacties af, voordat ik 'em ga gebruiken... :Y)
MW | BF1 Stats
  • KillerAce_NL
KillerAce_NL
Op vrijdag 22 maart 2002 11:02 schreef zephyer het volgende:
Ik zit nu op het werk, anders had ik em wel ff getest (symantec ghost rules ;) )
Kan je met versie 1.10 wel op 1.11 serverts????
Of moet je echt updaten???? :(
Nederlandse versie patchen kan ook met de Engelse patch, zodat je overal weer lekker kan gamen (Want alle servers hebben patch al)
  • [Jules]
  • Laatst online: 08:06
[Jules]
Confusion in confusion
Hij's overigens nu wel officieel vermeld op de mohaa website... 'k ben 'm aan het downen...ff kijken of het allemaal wil werken...
Knowing others is to be clever.
Knowing yourself is to be enlightened.
Overcoming others requires force.
Overcoming yourself requires strength.
Op vrijdag 22 maart 2002 18:06 schreef (roh)violator het volgende:
Nee je kan met de 1.10 ook op de 1.11
WTF killerace? ik ben het Streaming_Victim lol ik wist nie dat jij op het GOT zat :D
  • MartNL
  • Laatst online: 13-10 13:26
MartNL
Hij werkt prima bij mij hoor.
En de fps zijn toch weer een stukje omhoog gegaan.
Niet zoveel ongeveer 7fps maar toch.
Ik update pas als de official EA servers dat ook doen :)
//edit: en bij deze wil ik gelijk maar even The All Seeing Eye promoten http://www.udpsoft.com/eye/ i.p.v. gamespy :r
  • MartNL
MartNL
Op zondag 24 maart 2002 16:18 schreef Lighteye het volgende:
Ik update als de update er is.
EN ik gebruik de ingame browser. ;)
  • KillerAce_NL
KillerAce_NL
Op zondag 24 maart 2002 15:09 schreef goku13 het volgende:
I am everywhere ;)
  • KillerAce_NL
KillerAce_NL
Ik heb em nog niet getest, maar het schijnt dat je er wel gewoon mee op 1.10 servers kunt joinen?
// edit //
oeps nog niet helemaal wakker, 2 replies gedaan. ;)
// edit //
  • MartNL
MartNL
Op maandag 25 maart 2002 09:57 schreef KillerAce_NL het volgende:
// edit //
// edit //
Ja dat klopt helemaal!
