[C] 3 verschillende problemen in code*
  • Yokidrink
  • Laatst online: 24-06 10:17
Hoi,
Ik zit een beetje errug vast met onderstaand programma
er zijn 3 delen waar een of meerdere fouten in zitten en ik kan niet vinden wat het is. ik heb de delen waar de fout moet zitten gemarkeerd:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
 *  Program to work out the number of temperatures in
 *  each of 7 temperature bands
#include <conio.h>
#include <stdio.h>
float in_float(void);
void wait(void);
 * main() function
main()
int bands[7];
int i,number=0;
float temp;
clrscr();
 * First clear the temperature band array
 * DIT DEEL!! hoe krijg ik het gecleared
for (i=0; i<6; i++)
bands[7]=0;
/* TOT HIER
 * Display prompt and read in first temperature
cprintf("Enter temperatures greater than -100.0\r\n");
cprintf("Enter a temperature of -100.0 or less to stop the program\r\n");
temp = in_float();
cprintf("\r\n");
 * Main loop
 * TWEEDE DEEL... DE LOOP, CORRECT of NIET
while (temp >-100.0)
number++;
 * Determine the temperature band
 * DERDE DEEL... how to determine the band
while ((temp >=0.0) && (i<6))
temp=temp - 10.0;
i++;
bands[i];
 * Read in next temperature
temp = in_float();
cprintf("\r\n");
 * Display the results
cprintf("\r\n%i temperatures were entered",number);
cprintf("\r\n%i was/were less than 0.0", bands[0]);
cprintf("\r\n%i was/were 0.0 or over and less than 10.0", bands[1]);
cprintf("\r\n%i was/were 10.0 or over and less than 20.0", bands[2]);
cprintf("\r\n%i was/were 20.0 or over and less than 30.0", bands[3]);
cprintf("\r\n%i was/were 30.0 or over and less than 40.0", bands[4]);
cprintf("\r\n%i was/were 40.0 or over and less than 50.0", bands[5]);
cprintf("\r\n%i was/were 50.0 or over", bands[6]);
wait();
 * end of main()
 * function in_float()
 * inputs a floating-point number from the keyboard
char tbuff[12];
float d;
tbuff[0] = 10;
cgets(tbuff);
if (sscanf(&tbuff[2],"%f",&d) < 1)
d = 0.0;
return(d);
 * end of in_float()
 * function wait()
 * waits for a keypress
void wait(void)
cprintf("\r\nPress any key to terminate");
getche();
 * end of wait()
Degene die het weet.... je bent een ster!!
[edit van dusty: Ondanks de vraag om code tags toe te voegen, heeft meneer de topic starter dat toch niet gedaan. Dan doe ik het maar omdat meneer te lui is om het zelf te doen.]
  • Soultaker
  • Laatst online: 09-09 11:02
LEES DE FAQ!
* Soultaker kan 's avonds laat geen beleefdheden meer opbrengen
  • Yokidrink
Op vrijdag 22 maart 2002 02:17 schreef Soultaker het volgende:
LEES DE FAQ!
Well.. duh.... dank je voor deze informatieve reactie
net wat ik nodig heb na een paar uur bloed sweet en tranen.
  • Soultaker
Op vrijdag 22 maart 2002 02:30 schreef thoth het volgende:
Dan kon even de FAQ lezen er dus niet van af?
* Nette code: code tussen [code]-tags!
* Maak een duidelijke omschrijving van je probleem.
* Geef aan wat je al geprobeerd hebt.
* Geef aan wat er fout gaat, wat voor foutmelding je te zien krijgt en op welke regel de fout staat.
* Zorg dat je topic-title duidelijk is, (maak een duidelijke omschrijving) en zet vooraan tussen haakjes om welke taal het gaat.
* Denk na voor je replied; (als ik zeg dat je de FAQ moet lezen; doe dat dan!)
Misschien heb je hier meer aan of moet ik 't nog verder voor je uitkauwen? Een antwoord op je vraag krijg je van mij sowieso niet meer.
Jesus he, het is ook wel ontzettend obvious allemaal. Huiswerk zeker? En geen zin om zelf wat te leren?
  • Dido
  • Laatst online: 10-09 17:04
Dido
heforshe
for (i=0; i<6; i++)
bands[7]=0;
HINT: ik denk dat bands[7] ondertussen wel op nul staat, maar met de rest doe je niets?
Wat betekent mijn avatar?
  • Yokidrink
Soultaker
1> ja ik had die faq niet goed gelezen.. admitted
2> ja ik had mijn probleem niet goed uitgelegd
Maar dan nog, ik gaf af op het feit dat je me de virtuele trap onder mijn kont geeft.. whatever.
Dido,
band[7]=0 ik dacht ook dat ie dan wel gecleared was maar ik moest een if constructie gebruiken om alle bands te clearen en daar ging ik dus fout, het moest zijn band[i]=0
Het tweede deel:
number++;
zit volgens mij wel goed aangezien de output het juiste aantal nummers weergeeft.
Het derde deel:
temp=temp - 10.0;
i++;
bands[i];
Hier moet een while constructie staan die de temperatuur input assigned in de juiste band.
Ben hier compleet op stuk gelopen en heb gister van 's middags tot 's nachts mijn tanden kapot gebeten en kan d'r gewoon geen oplossing voor vinden.
de output die ik krijg na de temp 1,40 en -100 ingevoerd te hebben is als volgt:
-100
2 temperatures were entered
0 was/were less than 0.0
0 was/were 0.0 or over and less than 10.0
0 was/were 10.0 or over and less than 20.0
0 was/were 20.0 or over and less than 30.0
0 was/were 30.0 or over and less than 40.0
0 was/were 40.0 or over and less than 50.0
5294 was/were 50.0 or over <<<<<<<<<<---------!!
  • Sjaaky
  • Laatst online: 03-09 23:48
als 1e:
for (i=0; i<7; i++){  //LET OP: i < 7
  bands[i]=0;
als 2e:
while ((temp >=0.0) && (i<6)) {
  temp=temp - 10.0;
  i++;
bands[i]++;  //LET OP: ++
Dit zou het ongeveer moeten zijn. :)
gebruik svp code tags, deze code is echt onleesbaar...
/* zo dus */
int
main()
  blablabla;
:Y)
  • Yokidrink
Op vrijdag 22 maart 2002 13:25 schreef Sjaaky het volgende:
als 1e:
  bands[i]=0;
als 2e:
  temp=temp - 10.0;
  i++;
Tnx
dit lost inderdaad het probleem gedeeltelijk op. Ik snap hem nu van die bands[i]++
enig probleem is dat de temeperatuur nog steeds niet opgeslagen wordt in de juiste band
ie
output voor temp 1.0 zou hem in bands[2] moeten plaatsen maar de waardes blijven 0
ps... sorry about de tags, het maakt het er inderdaad niet duidelijker op
  • Sjaaky
hint: je kan je post editten :Y)
  • Sjaaky
Oh wacht dat ben ik er vergeten bij te zeggen. Je moet i weer op 0 zetten na bands[i]++;
  • Yokidrink
Op vrijdag 22 maart 2002 13:48 schreef Sjaaky het volgende:
Je bent een ster!!
het werkt :-)
owe u one m8 *D
  • Yokidrink
hij werkt op een 'klein' detail na:
kijkend naar de output wanneer je 100 temps hebt ingevoerd krijg je het volgende resultaat:
100 temperatures were entered
12 was/were less than 0.0
8 was/were 0.0 or over and less than 10.0
17 was/were 10.0 or over and less than 20.0
16 was/were 20.0 or over and less than 30.0
19 was/were 30.0 or over and less than 40.0
17 was/were 40.0 or over and less than 50.0
10 was/were 50.0 or over
hij plaats de eerste waarde niet in een band, de overige 99 wel.
  • Sjaaky
i op 0 zetten voor de 2e while lus ipv na bands[i]++; ?
Maar voor dit soort dingen zijn debuggers uitgevonden.
  • Yokidrink
<close pls>
bedankt voor de hulp, ik weet een ding... ik blijf ver van programeren :)
  • Soultaker
Op vrijdag 22 maart 2002 15:48 schreef thoth het volgende:
Blijf dan ook weg van programmeerfora.
(PS. Code tags hebben ook niet zoveel nut meer als je de layout al verneukt hebt.)
